Old 03-10-2013, 09:18 PM   #11
MyzticZ3r0
Jon Webb does indeed know his stuff. He's standup guy. He comes off a little high strung to some people but his work speaks volumes. He was installer of the year in 2011 with that Pontiac G8 Arc Audio install. He and I have talked at length about it and I've actually demoed the vehicle a CES.
What was mentioned about you having a HB is significant actually. You're going to have a nice response bump around 39-42 Hz in a Yaris given whatever enclosure. It's just how the car's resonant frequency is...
I offered Myz my DD S4b and my ML3800 (loaded in a 1.5^3 sealed enclosure). Depending on his budget, this could really take care of any issues he might have. Heck, even with stock speakers off that amp you'll be better.
I actually went to the 2011 CES convention, but I must've missed the demo of the g8. Too bad - I could've used the insight on SQ and something to measure myself to.
No need to talk to the mechanic. L7's will require a ton of airspace. for a single sub you'd need the whole hatch area and barely have what is required. For a pair you'd have to build a box that would take up your Hatch as well as all or most of the seats folded.
For what you're trying to do you have a few options :
12 inch Shallow Mount Sub
10 Inch Low Excursion Sub ( Won't require alot of airspace )
(2) 8 inch subs
I see the required RMS to be around 500 watts RMS For that type of setup.
It's also going to be more Sq and not so much Spl just because you won't be using alot of airspace. Another words it won't be as boomy, then again it is a hatch.
That guy SQ suggested will know his stuff. Lets see what he recommends.
I did actually stop by Best Buy on the way home today to check out those two 12" kicker subs in the box - it barely fits in my hatch area. I will admit I love the idea of having two 12"s, but I do use my hatch frequently. Another problem, as I mentioned to SQ, was that I want my system to be incognito when I'm not in the car. Unfortunately, the rate of stolen vehicles in Vegas is abnormally high and I don't need to give them any more reason to take my car. I am, however, open to other ideas!
I'd let your buddy set up that amp and show him where his volume on his radio should be and he'd have a hell of a system.
Holy Hell that sub is a 15 ?
Myz thats a hell of an amp and sub. You went straight to the top with equipment like that. Hell if you don't take it i'd consider that Deal !
Yea I overlooked the 15", it's a monster! I am considering it, but as reasons posted above, I need to think it over.
MyzticZ3r0 is offline   Reply With Quote
Amplifier for Audiobahn Bandpass Enclosure? PSYS In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2012 05:07 PM
FS: Alpine Double Din, 180mm Trim, Subs, Amp Taiyaki Items for Sale by private party 2 03-21-2010 06:17 PM
RMS capabilities Slick In Car Entertainment + Electronics (audio / video / alarm) 31 08-21-2009 09:52 PM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
can i hook up an amp and subs to stock h/u? jeremyshay In Car Entertainment + Electronics (audio / video / alarm) 12 01-08-2009 03:07 AM
