#19 |
The way I understand it...
Manual shifting of an auto transmission is not a problem in theory. In fact, it should not cause any problems, most of the basic "sequential" boxes are just that, automatics with gear change overrides. (BMW's SMG and fancier sequentials are basically an automated manual gearbox, but I digress). As with any other mechanical component, if you use it within its normal parameters, there should be no problem shifting an A/T. But, just like with anything else, problems arise when you abuse these normal operation parmeters. Auto transmissions are inherently less robust than manuals, coming in to a corner at speed and using ONLY the gearbox's downshift to slow yourself down is probably not a good idea. Just like the manual Razr posted up above mentions, the main problem is overheating of the transmission. So, the Cliff's Notes: A/T shifting? Not too much to worry about as long as you don't thrash the thing or force it to run in low gears excessively. Just like anything "fun" you can do with your car, there's the chance of it reducing the overall life of the vehicle.
#20 | |
MPG is the new cool
Thanks -Peter
#21 | |
Drives: 2007 Yaris LB Join Date: Mar 2007
Even in the Toyota Yaris manual for A/T, Toyota writes that up/down shifting the A/T is fine, they include this in our manuals for A/T, so long as it is done with in speed/gear constraints. "Manually" shifting A/T's, when done right, will not lower the longevity of an A/T. However if done wrong, and over time, it could cause tranny failure in under 50,000 miles, or less, so if done right, no worries....if done wrong, you might have a huge tranny repair bill on your hands. WASTE OF TIME? Not really. If done right downshifting/upshifting an A/T can be VERY beneficial, like coming into a turn with the desire to keep the rev's up, just to name one of MANY reasons to shift an A/T manually....doing this is very beneficial to sport driving, and even zipping around the highways, through traffic, etc... |
#22 |
SORRY FRIEND, BUT YOUR RESPONSE IS SHOWING YOUR PROFOUND IGNORANCE OF DRIVING AN A/T....but I cut you slack, because A/T in Europe is not often used, and therefore people there really don't understanding manual shifting of A/T cars....but here in the states, we do....many of us do this...it can save on brakes, because manually shifting an A/T means one can use the engine as a brake, etc....
#23 |
GIGA...DRILL...BREAKER!!!
Drives: Lagann. ;P Join Date: Feb 2006
From my own (very) limited experience, auto transmissions with the manual override (+/- shifter), SUCK. I've driven 2 different cars with this feature, and both of them took entirely to long to accomplish the task. I can't stand that delay between hitting the lever and the actual gearshift... drives me nuts, and useless for a sporty driving style. Plain old automatic shifting seems quicker.
And actually Pavel, he's very correct. All he said was manual, need to shift (obviously), and auto, no need, which is also true. What kind of weird ass trannys (don't get all excited now) do you play with over there that manuals DON'T have to be shifted and autos do? ~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
#24 | |
When downshifting manually an A/T, bleeping the gas as you downshift will get it in gear RIGHT NOW! Manually down/up shifting an A/T is not as simple as moving the gear selector....you need to use your gas pedel too, depending.... |
#25 |
It IS that simple when it's built in. Hit "+", it upshifts, hit "-", and it downshifts. No gas adjustments are necessary. I believe you're talking about a standard auto, while I'm talking about the "manu-matics".
~YR
#26 | |
Think about this too: Most people that drive manual trannys don't know how to drive them properly. One more thing: Most people that manually shift an A/T don't know how to do it properly either. For an A/T, when you hit the + or - selector, the tranny will not necessarily shift the gear UNLESS the tranny revs and the engine revs are happy with each other....this is the same thing when down shifting a manual...to save the clutch, to keep it smooth. The fact that the A/T's that allow + and - manual gear changes is not responsive is the driver's fault, his ignorance of how to up/down shift an A/T properly...and not the car's fault. |
#27 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
Ok fine. I am talking out of my ass. You are right I am wrong. I still dont belive you. Why? Because the first car I had was a automatic transmission, and I was 16 and thought I was speed racer and shifted it like it was a manual. 30k miles later it lost second gear from the teeth comming off the sun gear. What I explained about the sun gear was exactly what happened to my car. So, I asked several transmission shops what would have caused this and they told me manually shifting the car is what did it.
The same thing has happened to two other people I know. I will not debate this subject any longer. If you guys want to yell and holler at me, by all means do it, I was just trying to save you from a mistake I made when I was young and foolish. By all means, if you are going to be assholes, please, F--k up your cars, and IF something does happen to your transmissions, fair warning, I am going to laugh my ass off. P.S. in that manual you posted for me to look at, did you notice that it says never to shift gears up with your foot on the gas pedal? Wow, so the manufacturer says that you aren't supposed to do that...so, in taking your foot off the gas pedal so you can shift, you are telling me it is faster to shift in a corner than letting the slusbox shift on its own? Nice.
#28 | |
So then at age 16 you blame the car, and hold yourself blamless for driver error? Where is the personal responsability? Just admit it, your car probably failed because you were a 16 year old newbie that didn't know shit yet. There are millions that manually shift their A/T's and have no issues with their A/T's 100,000+ miles later. As for pressing the gas pedel during shifts, IT IS FOR DOWNSHIFTING, not UP shifting...I thought I made that clear...and gassing it during down shifting does NO harm to the A/T tranny....doing so during upshift can be bad however. You keep twisting my words....coming into a corner, manually downshift the A/T while you gas it, to get it to drop NOW, and keep the rev's up as you make the corner....this is how pros drive AT's...this is nothing new, and this is the proper way to enter a corner with an AT....why do you think car makers allow the selectors to be manually placed in 3, 2, 1? Not just for getting out of snowy conditions...there are other reasons....stop twisting my words and learn ;-) |
#29 | |
MPG is the new cool
Oh and by the way, So you killed a A/T when you were 16.. I'm guessing that was no more than 5 years ago. Further you neglect to share what type of car it was, the condition, and whether you only down shifted into turns. All this tells me is a another teenager killed a car.. Whoopie, name me 2 teens that did not kill at least one car in some way or another as they learned to drive, thats why it's called "learning". -Peter
#30 |
![]() ![]() ![]() Drives: Black 2007 Yaris Liftback 1.5 Join Date: Jan 2007
There's no need for the discussion to eb this heated. Does anyone have any outside (i.e., non-message board) voices on the subject.
These were the main two I could find: http://www.startribune.com/131/story/163720.html http://www.canadiandriver.com/articles/jk/030806.htm Several other message board threads too, but I think we've got enough of those sorts of voices going already, though they seemed to fall more on the "not causing any harm unless you do something really stupid" and "almost impossible to do something really stupid, because of rev limiters" variety than anything else. Other links (especially those dealing less with engine breaking and more with keeping revs up to pull through a corner) are welcome. Perhaps someone else can find more than I did. |
#31 |
a Rev limiter is not going to help if one downshifts wrong...doing it wrong can hurt your engine over time without red lining the tack....it's fine if it is done right...done wrong over time can shorten the life of the tranny and perhaps the engine too, stressing many parts.
#32 | |
The Hated One
wow dude. I am not getting pissy, I admitted that I was apperantly talking out of my ass. I was 16, that was about 7 years ago, it was a brand new 3spd auto chevrolet cavalier. I downshifted into turns, and also used the 1-2-D method when accelerating. So yes, I did learn. I learned not to do that, and I tried sharing my personal experience here. Spare me your high and mighty attitude about how I am the one that is hostile....your first reply to this thread you used the F word. I responded after several replies of yours that I was wrong, that you were right, and that if your transmission took a dump on you that I would laugh, and I will laugh if I see a post about your transmission slipping. So, admitting that you are right and I am wrong to you, is my butt hurting? I offered my opinion to this debate and all you could do is say "that it has never happened to you" and then get hostile when I point out my reasons for thinking this is hard on transmissions. Also, read that manual that was posted in PDF form, it says "Never put your foot on the accelorator pedal while shifting"...its the thing noted by the little caution sign...thats what I was refering to...I mean, you guys are the ones pointing stuff out in the manual, I was just reading what it said. So, to recap, I am not pissy, I have shared with you the information about my car, I have not yelled or hollered yet, and you need to read the manuals that you post that are a attempt to prove me wrong. Mmmmmm'k? thanks.
#33 |
![]() Drives: Sedan Join Date: Mar 2007
"Autostick"
Is the yaris automatic transmission an "autostick"? Or am I completely way off?
http://en.wikipedia.org/wiki/Autosti...with_Autostick |
#34 | |
MPG is the new cool
You have confused me with at least two other posters.. I started the thread but I've not used the f-word, I did not post the Manual, and saying you'll be happy if one of our cars breaks down is just plain hostile. Further, if any of your responses were in any way really an acknowledgment of error.. well then I'm sorry.. But it sure does not read that way, I've read them a number of times and every single read through they come off as sarcastic at best. -Peter
#35 | |
![]() ![]() ![]() Drives: Yaris 3dr Hatchback Join Date: Oct 2006
engine rpm from going into the red zone." This was my favorite part, taken from the warning in the automatic section. Tell me, HOW THE FUCK can they say that when our cars don't come with tachometers? makes me want to do something about it. |
#36 | |
The Hated One
I apperantly don't know what I am talking about, we will leave it at that. So far no one has given me a explanation about how my theory(about the sun gear failing from stress that downshifting causes) is wrong. All I have heard are people saying that I am wrong...I was just hoping for a post that someone would actually tell me WHY I am wrong, other than "I did it for years with no problem". I dunno, this is turning into a flamefest, so this is my last post. My intent was not to anger anyone, simply to explain what I belive to be true...not a opinion, just the facts that were given to me by transmission shops. My input is not welcome, so, I will leave you with what I posted and call it good. P.S. you can tell you down shifted to far if the engine RPM's go through the roof and the engine starts shutting on and off really quick...sounds something like "Vroom...slam...vrooom....slam" you will hear it pop back and forth really fast and loose power, it can sometimes cause the car to shudder...thats the computer shutting off the fuel or ignition to keep the engine from spinning too fast...go rev limiter! EDIT: and my responce prior to that was aimed at more than one person Dag, I should have typed out seperate responces, I was aiming it at all the flamers, not just you. I was not paying attention to who was flaming me so I just put up a general post to all the haters.
| Shifting.. | PixieDawn | General Yaris / Vitz Discussion | 34 | 03-01-2009 06:58 PM |
| Mystery socket on A/T console | rockchops | General Yaris / Vitz Discussion | 20 | 04-10-2007 10:14 AM |
| Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
| Shifting RPM | GabL | DIY / Maintenance / Service | 10 | 08-06-2006 05:40 AM |
| Auto Shifting knob ? | Boo | General Yaris / Vitz Discussion | 8 | 07-24-2006 07:21 PM |
