Originally Posted by wildmongoose26
Picked up a used kit for a screaming deal local. Came off a yaris so shouldn't be any issues with the TB fitment. Do need to find the right spacers and make some new gaskets but other then that all set to go
Finished the wiring last night and doing the rest of the instsll Saturday. Just have to wire up the wideband and boost gauge between now and then.
Oh, and have a bit if super JDM rareness on the way. So much so I've only ever found one car sporting it, abs that car lives in Japan
I just did the mechanical part on mine. Common issues seem to be air leaks - hence I used gasket maker stuff as all my gaskets are not new and that notorius center nut on the SC manifold. What I did: I measured the stud - how deep it goes inside and then created a bolt by combining the stud and the nut and left it @stuck@ in the manifold- was pretty easy to install the manifold later (studs on the side do a good centering job).
Good luck with your project
