Old 03-28-2013, 10:28 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
Missfire is either mechanical / electrical / or fuel related. If the missfire happens when its more under load then its usually electrical such as a coil. One way to test it is remove the coil from cylinder 4 and switch it with cylinder 3. See if it sets a code p0303 then its a defective coil. If it still sets a code p0304 perform a compression test on cylinder 4 to eliminate burn valves or ring issue. At that point with process of elimination you know you have a stuck injector. You could try chevron fuel system cleaner or a bottle of seafoam in your tank and hope for best. Otherwise it will need to be replaced.
random pic smofskra Photo-Video-Media Gallery 3 06-04-2011 10:53 PM
P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire dante2086 DIY / Maintenance / Service 4 05-15-2011 04:36 PM
FS: Bnew Porter Cable 7424 Random Orbit Polisher - NJ jeff_o Items for Sale by private party 3 01-30-2010 07:53 PM
Random feature Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 7 12-17-2006 05:24 PM
