Old 04-07-2009, 11:45 PM   #1
NonStopTuning
Originally Posted by RogueYaris View Post
I sent NST a pm about 9 days ago and haven't received a response yet. Either way, I was wondering about how long it would take a dealership to install one of these?
I don't believe I received this PM. Either way, installation should require less than an hour by a pro mechanic.
Good luck and have fun with all your projects!
MIKE @ NST
www.NonStopTuning.com
Old 04-07-2009, 02:54 AM   #2
RogueYaris
Drives: 2015 Abs Red
Thanks for the quick reply ruimond. My dealership only charges $40 an hour on accessories and these actually fall under that category.
RogueYaris is offline   Reply With Quote
Old 04-07-2009, 08:26 AM   #3
hatchbackkid82
Drives: .
Just ordered mine today. Can't wait to get them
Old 04-07-2009, 09:42 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey guys , had mine on my 1300cc 2nzfe ncp91 yaris for a while already , acyually almost 2 years i think , so far , no problems , still goes really well , guys cant believe how my little car goes , will put a clip on some time to show you.BIG UP NST!!!
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 04-07-2009, 11:46 PM   #5
NonStopTuning
Thank you sir
MIKE @ NST
Old 04-10-2009, 11:07 PM   #6
xbalance
Drives: stock
guys do any of you all notice the engine Vibration increase abit after install pulley set?
Most easy notice is during idle time...
xbalance is offline   Reply With Quote
Old 04-12-2009, 04:51 PM   #7
NonStopTuning
So I drive pretty spiritedly. I used to get about 35-36 mpg when i used to do a mostly freeway commute. Now because of my new job i drive in stop and go traffic to and from work. And usually get 29-31 depending on how i drive.
I would assume with the NST pulley since it is lighter and less rotational mass one who does more stop and go driving would benefit more from it than someone who does mostly longer consistant speed commute. Since it requires less power from a stop to go than it does to keep at a constant rotational higher speed.
And my last tank jumped to 35mpg. The most i ever got for months. I am hoping its not a fluke as there are many variables. But im awaiting to post my results again the next fuel up. If its the same than the pulley will pay itself of in fuel ecnomy alone especially if gas prices rise. I drive very aggresively so i can imagine if i backed off the throttle a bit i would get even better results. I hit redline on a daily basis.
MIKE @ NST
Old 04-13-2009, 08:31 AM   #8
hatchbackkid82
Drives: .
Just installed mine yesterday...nice improvement all through the power band. Noticeable at top end
Old 04-14-2009, 12:24 AM   #9
gmodder
Riceman43
Drives: 2009 Yaris 3door
bump
gmodder is offline   Reply With Quote
Old 04-19-2009, 07:21 AM   #10
Klinton
Klinton's Avatar
Drives: 2009 Yaris sedan Flint Mica
mines going in soon im pumped!
205/45/17 Nittos/ KN tyhoon 69 intake
EURO areo muffler / DF 210 Springs
NST 10% Pulley/ 15% tint
600watt rockford punch 12" subs and amp
micro image rocks!
Klinton is offline   Reply With Quote
Old 04-20-2009, 02:52 PM   #11
Deltasix
Deltasix's Avatar
Drives: '07 Liftback: Work in Progress
Send a message via AIM to Deltasix
Installed mine a few weeks ago, certainly can feel a bit more response on the lower end (went with the underdrive pulley). Noticed a bit better fuel mileage than before, not a drastic change or anything of the like, but anything is appreciated!
"The basis of optimism is sheer terror."
Deltasix is offline   Reply With Quote
Old 04-20-2009, 04:37 PM   #12
gmodder
Riceman43
Got my set installed Friday...Definetly a nice improvement...Iam also seeing better gas mileage. Engine is just as smooth as before if not better....
As far as the performance. Well my heavy ass 17" wheels are kind of killing that..LMAO..
Old 04-20-2009, 04:39 PM   #13
i was just hoping it could be noted somewhere that a new belt is req'd if you don't have a/c
I'll note this for my store - Do you know the part number of the shorter belt that worked?
Old 04-22-2009, 05:23 PM   #14
Klinton
Klinton's Avatar
i just finished putting mine in its sweet thanks micro image again for being great
micro image rocks!
Old 04-27-2009, 03:50 PM   #15
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
I ordered one from garm last week, its coming in a couple of hours. I killed some time by getting off the stock crank pulley manually with no impact wrench and well....I must be the strongest guy on YW cause that has got to be the easiest thing I've done on my car. I literally did it while lying on my back...ha! All the bolts were super easy for me to get off, that or my car didnt come out of the factory with the bolts torqued properly, lol. First time I've really been excited to see the weird UPS delivery guy. I'll post pix soon!
EDIT:
4 hours later ups arrives...then install! I havent gone to bed yet so I was too tire for pix, sorry. Anyways heres what happened when I first got in the car...
First thing I noticed was the idle was almost unoticeable. It felt as if my car wasnt even running. Definitely a lot quieter too, it was scary at first haha. Throttle is more responsive, the shifts are so clean and smooth in my auto. Power increase within the mid range, hrm...need to drive more tomorrow to see more...hehe.
Thanks NST, garm, and chinocharles' diy.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 04-28-2009, 10:52 AM   #16
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
So did anyone see any HP gains with just the light crank pulley (not underdriven), and the OEM WP and Alt pulleys?
Thanks!
Old 04-28-2009, 05:09 PM   #17
Astroman
Modded Moderator
Astroman's Avatar
Thanks!
Really, the lite pulley frees up HP from the crank that would otherwise be wasted moving a considerably heavier pulley. Seriously, you could use the stock pulley as a boat anchor (albeit on a very small personal boat, but still you get the idea.) Also a plus on the automatic is it helps resolve "gear hunting" up hills.
Old 05-01-2009, 03:29 AM   #18
eii
Rides canyon walls
eii's Avatar
Thanks!
I have JUST the light crank pulley and it made a world of a difference. I had the battery disconnected while I was working on the pulley and some electrical stuff so I guess it took the ECU a couple of day to 'learn' the new revs. Theres a definite increase in power all throughout the power range. I could only imagine the addition of the WP and ALT will increase power even more. Honestly just the difference you feel at idle and shifting is worth it, I just consider the HP a cool bonus.
The stock pulley is way heavier than the NST one. I was playing with the stock one earlier today and dropped it on my foot...OW...
I did notice on my auto sedan when going up a hill it didnt do that stupid gear hunting .
