+1 for what scott said you would definitely hear a growling noise form the engine at low speeds that would increase with engine speed if the bearing was bad. The slop he is probably referring too is if you grab the axle shaft closest to the transmission and pull up an down on it, there is excessive movement which could be easily misdiagnosed as a bad bearing but could simple be a failing inner cv joint.
| Wheel Bearing? | devinlamothe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 07-12-2015 12:59 AM |
| Alternator Bearing | barryware | DIY / Maintenance / Service | 7 | 11-23-2013 06:33 PM |
| Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-24-2009 11:08 PM |
| The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 08:38 AM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
