Old 05-06-2013, 10:12 PM   #1
Sooke
Drives: Toyota Echo
Easy A/C Fix
My 2000 Echo's A/C didn't blow cold. It turns out the low side pressure was fine, but the compressor wasn't turning. I read somewhere that the A/C compressor's clutch eventually wears down so it doesn't grab the pulley anymore, and that sometimes removing spacers can move the clutch enough to allow it to grab. I took off the bolt on the compressor pulley and the spacer fell off. I put the bolt back on, and now I'm COOL!
Sooke is offline   Reply With Quote
Old 05-07-2013, 12:16 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im actually curious on what spacer are you refering to.. i may have the same problem..
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
