#19 |
^ 'Frank' looks good man.
#20 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
#21 |
^^ Yes i am using an Audi 710N diverter valve.
#22 |
1. 2007 HB
2. Zage Turbo 3. Haven't dynoed it 4. About 2 weeks - ~100 miles 5. No problems yet, just working out the tune. 6. ![]()
#23 |
2ZR swap. DO IT! Ask how!
1. '09 HB
2. Blitz S/C 3. No dyno yet 4. About a month, about 2000 miles. (About a week, about 300 miles.) 5. Was running lean, fixed with green 1ZZ 255cc injectors. Threw a P0101 code twice on the way home from AutoX this past weekend, apparently a known issue for some Blitz owners. Massive inside wheel spin on hard corner acceleration. (No CEL's or anything, but dealing with significant belt squeak when the clutch engages.) 6. Here's a placeholder until I get my intake installed: ![]() Here's the important parts, just after installing the injectors:
#24 |
^ Epic!
#25 | |
With the S/C you have to really tighten the belt. With that extra length there is a lot of stretch.
#26 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Stickied.
#27 |
Boosted Echo
1. Year and Type of Yaris (sedan or liftback)
Echo 2005 liftback (is it a problem :P??) 2. Type and brand of FI system (Blitz Supercharger, Zage Turbo, etc.) Garrett GT2252/ Garrett GT2554R, custom fitment. 3. Horsepower and Torque (if you have dynoed it) On a mustang dyno @5.75psi = 145whp/145wtq ... I got those numbers with a wastegate leak at the diaphragme plus another smaller leak at the boost gauge 4. How long it has been boosted (years and/or mileage) Boosted @180,000kms, up to date @240,000kms 5. Any problems that you've had due to being boosted. Biggest problem = OEM ECU 6. Post an under-hood photo to show what-you-got I don`t have up to date picture at the moment |
#28 |
![]() Drives: 2008 liftback Join Date: Dec 2010
2008 blue HB with 106,000 miles on it.
Has a Zage kit running 10psi with a boost controller. Tuned with AEM fic. No idea what the HP is but it spins the 199/55-15's at 40mph when the turbo kicks in and chirps them again on the 2-3 shift. ![]() Nearly two months since the install and about 4,000 miles. No major issues(knock on wood). No pics yet. |
#29 |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
1. Year and Type of Yaris (sedan or liftback) - 2009 RS, Liftback, 5spd, Blizzard Pearl
2. Type and brand of FI system (Blitz Supercharger, Zage Turbo, etc.) - Blitz Supercharger (1NZFE) 3. Horsepower and Torque (if you have dynoed it) - Have not dyno'ed it yet. I assume in the mid to high 130's HP range with CAI/H/E and lightweight crank pulley. 4. How long it has been boosted (years and/or mileage) - 500km lol 5. Any problems that you've had due to being boosted. - Had belt slippage at higher RPM (common problem with Blitz kit), but was resolved / band-aided by tightening the belt past OE specifications. No other problems at the moment. 6. Post an under-hood photo to show what-you-got
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
#30 |
conundrum562
Drives: Toyota Yaris 2007 S Join Date: Jun 2010
1. 2007 TYPE S (SEDAN)
2. (Blitz Supercharger) 3. (N/A) 4. (01 DAY - 96,000 MILES) 5. RUNNING LEAN hopefully fixed: I've upgraded my injectors to the 1ZZ PN 23250-0D050 and it makes the car idle very good, less shaking and more throttle response. As far as the check engine light lean code goes, I haven't seen it come on yet. Hopefully it doesn't anymore. 6. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
--------------------------------------------------------------- BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
#31 |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
1. 2009 Yaris liftback
2. Was blitz supercharged, now Zage Turbo'd. 3. Used to be about 130/130, haven't dyno'd it since being turbo'd. 4. Had the blitz Supercharger on the car since early Spring of 2014, had the turbo since Summer 2015. 5. Mostly the belts on the supercharger. I had some pretty bad slip initially on the belts of the supercharger due to their skinny nature, when I finally managed to get them to stick I sheered the pin on the crank pulley off and had to make a new one. You also have to find a belt that's the right length and cut it in half, which if you don't get them just right makes the belt uneven and potentially shortens the life significantly. I fixed the belt slipping at high RPM's with some belt dressing. Now that i'm turbo'd, the only problem I have is due to my lack of a tune which is causing the car to run lean on idle, and super rich under WOT, but that should be fixed soon. 6. ![]() ![]()
#32 |
Drives: Yaris Turbo Join Date: May 2012
1. 2010 HB
2. Custom t25 / now t28 3. 133whp / not Dyno'ed 4. 3yrs first kit / 3 months and it's in process 5. Blew engine first week, No issue after that. Was running 7 psi, stock internal and ecu, 1nz injectors. Now almost everything swap including 1zz intake and 1zz electronic throttle. 6.
#33 |
Modded Moderator
2007 Liftback 2. Type and brand of FI system (Blitz Supercharger, Zage Turbo, etc.) Blitz Supercharger 3. Horsepower and Torque (if you have dynoed it) Not yet, will after F/IC is installed and car is tuned 4. How long it has been boosted (years and/or mileage) Since October, about 1,000 miles 5. Any problems that you've had due to being boosted. Used belt issues, then I bent the adjusting bolt. Now having trouble aligning the adjuster pulley. 6. Post an under-hood photo to show what-you-got |
#34 |
![]() ![]() Drives: Vitz & Supra Join Date: Jan 2011
1. 2001 Echo/Vitz RS NCP13 (1NZFE)
2. Blitz Supercharger - 5Zigen Headers, High Flow Cat, Fujitsubo Axel Baack, TopFuel 1000 Induction with K&N Filter, and E-Manage Ultimate 3. 76FWKW 4. How long it has been boosted - About 4 months, and 1500km 5. Any problems that you've had due to being boosted. It drives crap under 3.5k rom 6.
#35 |
Drives: 2012 Yaris 4dr Join Date: Jul 2020
Why isn’t there a Yaris from 2011+ on this list?
#36 |
1. 2006 RS 5-Door Hatch
2. 2ZR-Swapped, T28 adapted Corolla turbo kit, AEM F/IC-6, DIY water/methanol injection, DIY trans cooler with thermostatically-controlled fan. 3. 180 WHP - Estimated 4. About a year, 6 - 7K kms 5. Nothing major. Occasional tune tweaks needed 6.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-10-2020 at 02:04 PM. |
| Tags |
| boosted, list, supercharger, turbo |
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Almost 10,000 Yarisworld Members! | kimona | Off-topic / Other Cars / Everything else Discussions | 14 | 04-01-2009 07:07 PM |
| The Official "Bambo the Yarisworld Traveler" thread (V1) | nemesisz | Off-topic / Other Cars / Everything else Discussions | 3 | 11-08-2008 10:24 PM |
| EBAY Seller Alert for Yarisworld Members | redyaris | DIY / Maintenance / Service | 29 | 07-02-2007 09:23 PM |
| Yarisworld Parts List - Work in progress | vodkalush | General Yaris / Vitz Discussion | 5 | 02-13-2007 06:12 PM |
