![]() Drives: 07 Yaris Join Date: Apr 2013
Electrical woes
Am new to working on my '07 Yaris, and when replacing the water pump and pulley, I pulled the alternator off to get better access. But stoopid me forgot to remove the negative terminal off the battery - got a nice little spark when the alternator pivoted forward and made contact.
Now that the water pump is replaced and buttoned up, I noticed I was missing some functions when running the engine to burp the radiator. Have no radio, AC, turn signals, wipers, etc. I found this link searching here, but I don't know which fuse Mattneto15 meant by "... A1 fuse under the dash, 25LP." Any other troubleshooting advice would be appreciated. |
Actually, check the two fusible links on the positive battery terminal (under the red cover). You will find one of them has blown.
Man! What a fast reply! Will check it out and update the thread.
I've not seen these fusible links before- I guess I can find them at WalMart or auto parts stores? Thanks again! |
The ones on the battery terminal are a Toyota only thing.
parts
Try this place it has good prices for OEM toyota parts. I used them when I order for my Tacoma Truck, I like them cause it helps to look at a diagram of what you're actually ordering. Toyomotorparts.com My yaris has been running flawless and hope it stays that way..LOL
OK, an update on the problem. I have some power- the car cranks and runs and dash/indicator lights come on.
From what I've searched, if the fusible links on the positive terminal were blown, I wouldn't get anything, right? None of the fuses seem blown. The weird part is that I pulled a few fuses under driver's dash and I have power to them (checked WIP, PANEL1, A/C). The 30A fusible links behind the change cup are both good also (checked w/VOM). I'm scratchin' my head. |
There are two separate links. If the 120A one was blown the car would not start, but with the 60A one blown it will start, but the dome lights, turn signals, radio, etc. will not work.
If you have a meter set it to the "Beeper" function and check the fuse out of circuit(pull the fuse out) and check for continuity. (Place a lead on each leg of the fuse) beep = good. No beep = bad.
I've ordered the fusible link from dealer. May get here today, otherwise I have to wait until Wed.
Bingo! It was the fusible link. Got the part this afternoon, swapped it out and all is groovy!
Now that the car is running and quiet after replacing the water pump pulley, I can hear more noises, so more projects.... Thanks to CTScott for the fix!! |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| electrical problem 2007 5 door hatchback | fford | Canada | 3 | 03-21-2013 02:02 PM |
| URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. | The Marshall | General Yaris / Vitz Discussion | 25 | 10-21-2010 08:23 PM |
| What electrical polisher do you use? | tomato | Wash, Wax, Detailing, Exterior Repairs | 11 | 09-01-2009 12:34 PM |
| What trailer electrical connector required? | charles nelson | DIY / Maintenance / Service | 3 | 01-16-2009 04:51 PM |
