Old 05-26-2013, 12:39 AM   #1
08yarisbroken
Drives: 2008 yaris
2008 yaris with intermittent power failures please help
Hello my 19 year old daughter bought this yaris used from the toyota dealer almost 2 months ago .. Her issue is when she goes to start her car she has no dash lights or interior or headlights no starter nothing like its completely dead. Then about ten minutes later its fine .
Every time I come to her rescue its already in a normal state.. door lights headlights, door dummy light.. no issues...
so I asked her to make a youtube video when it occurred again and it did a couple days ago. so if you can please help with an idea of what to replace that would be great.. If by chance the ecm is at fault can we just buy a used one from ebay and plug and play?
http://www.youtube.com/watch?v=v2Zv5...ature=youtu.be
when i arrived 5 minutes after this video was shot it was back to normal little blue.. ty guys for your help
08yarisbroken is offline   Reply With Quote
Old 05-26-2013, 06:34 AM   #2
I am thinking that the IG2 relay is causing that. It is part of the Integration Relay, which is an assembly within the under-hood fuse panel. When it occurs again, tell her to pop the hood and the cover on the fuse box and have someone put their ear close to the fuse box, listening for a click as she turns the key from the OFF to ON position.
Old 05-26-2013, 12:10 PM   #3
08yarisbroken
Drives: 2008 yaris
would the ign2 relay control all the key off power to the car too?
The headlight and dome lights didn't work when its showing its problem too.
Ign2 controls power to these also I take it..
If so for whatever the cost is I'm going to have to try that first Ive read your prior posts to say its about $110. or so.
Is the ecm then cleared of this being the fault. And is it coded or matched to the car?
I thank you sooooo much.. I feel like a jerk because i can't fix or find this problem asap. I don't want her safety jeopardized.
Old 05-26-2013, 12:19 PM   #4
Actually the IG2 relay would not come into play for the dome light. The ECM also could not cause this, so I would actually check the battery terminals for corrosion and the large connectors that plug into the back of the positive battery terminal for corrosion as well.
Old 05-26-2013, 07:48 PM   #5
08yarisbroken
Drives: 2008 yaris
ok i will inspect the wire and fuse area near the battery and firewall.
this car i believe was preowned in oregon and I can see a light coating of white corrosion all over the engine bay.
ty for your help
Old 05-26-2013, 07:58 PM   #6
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Sounds like the battery posts not sparking, need to remove them and clean them with sand papers.. posts and all..
yaris1F8 is offline   Reply With Quote
Old 05-28-2013, 10:07 PM   #7
Deshi Basara
Drives: 09 Yaris Hatchback
I had the same problem and did what yari1F8 stated above. After cleaning the battery post and removing the gunk out of it, the freaking car started and never had the problem since. Start small first then move to something big. Always check your battery first :)
Deshi Basara is offline   Reply With Quote
Old 06-01-2013, 04:31 PM   #8
08yarisbroken
Drives: 2008 yaris
found the problem, it was a loose ground at the battery post.
I'm unsure why stevens creek toyota didn't find it on their try.
But I am glad for all your support and hope you have a great one.
T
Old 06-01-2013, 08:06 PM   #9
T
Nice! I am glad to hear that it was resolved that easily. Hopefully it will provide your daughter with many years of reliability now.
Old 04-19-2017, 04:39 PM   #10
Goosecreekjoey
Drives: 2008 yaris
Yaris fuel trouble
Ctscott still online with Yaris help
Goosecreekjoey is offline   Reply With Quote
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
