Old 04-27-2013, 10:07 PM   #19
Originally Posted by thatbryanguy View Post
Update, got my 08 ECU in and the car runs good with that and I don't get the crankshaft position sensor CEL anymore when i plug the FIC in. BUT now my car dies out with 3 misfire codes. Random misfire, cyl 1, and cyl 3. What could this be caused by?
Excellent on the crank issue. On the dying with a misfire one, is your injector response time up at 810us or more?
Old 04-28-2013, 12:24 AM   #20
thatbryanguy
Drives: Yaris 3dr hatch
Yea it should still have that same cal file I sent to you loaded on the FIC. I'll plug it in tomorrow and check everything again.
thatbryanguy is offline   Reply With Quote
Old 04-28-2013, 10:57 PM   #21
thatbryanguy
It's set to 810us for injector response. Wonder what else could cause something like this.
Old 04-28-2013, 11:07 PM   #22
If you stick the FIC bypass connector on does it run correctly?
Old 04-29-2013, 02:29 PM   #23
thatbryanguy
I'm actually having trouble finding my bypass harness since my last install/removal. So I haven't tried that out yet.
Old 05-27-2013, 01:55 AM   #24
thatbryanguy
ok after a little break from the modding game and enjoying my new wheels, i finally got around to finding my bypass connector and it runs fine with it connected. Its only when the FIC is connected that the misfires occur. These misfires also occur in my fiance's sisters yaris.
Old 05-27-2013, 08:46 AM   #25
You don't by any chance have someone else nearby with a FIC, where you can try that in place of yours?
Old 05-27-2013, 11:04 AM   #26
thatbryanguy
I don't unfortunately...and I currently don't have the funds to pick another FIC up just to test.
Old 05-27-2013, 01:16 PM   #27
Maybe I should ship you mine to test with.
Old 05-27-2013, 04:16 PM   #28
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Since me and OP are experiencing the same problem with our 07 ECU, I'm going to replace mine as well. I found a slightly used one for $95. Gotta wait for it to get in, then ill update with results.
_______________________________________________
yariSB86 is offline   Reply With Quote
Old 05-27-2013, 06:26 PM   #29
fnkngrv as well. He swapped my FIC in and the problem went away, but we are going to try an 08 ECM on his as well.
Old 05-27-2013, 08:17 PM   #30
thatbryanguy
Man that would be a great help Scott but let me double check everything one last time before I bother you with all of that.
Old 05-28-2013, 12:14 PM   #31
If you haven't ordered it yet, I can now do the firmware updating on existing ones to load the new version that corrects the issue.
Old 05-28-2013, 07:02 PM   #32
thatbryanguy
Hmm, how much if I send you my '07 ECU just to have it updated? id like to run my original ECU if I could.
Old 05-28-2013, 07:30 PM   #33
yariSB86
yariSB86's Avatar
Darn, I just placed the order for my 08 ecu yesterday...wasnt too bad though, only $119 shipped. If that doesn't work: with bryans question, how much would you like scott? if we sent our stock 07 ecus to you.
Old 05-28-2013, 10:25 PM   #34
It's a pretty quick and easy job with my test bench, so I would do them for $25 plus the cost to return them to you (which was about $7 to ship fnkngrv's today). While I am doing the update I will also program the VIN for you, which is stored in ECM.
Old 05-29-2013, 01:06 PM   #35
thatbryanguy
So upon a final attempt to double check everything and re-install the FIC I found the vacuum line going to the FIC was torn. Didn't know if that had anything to do with the problem but I knew it wasn't a good thing and would cause some vacuum leak problem so I replaced it. Put everything together and started it up. No problems! It ran, idle fluctuated back and forth a lot at first but that was to be expected after disconnecting the battery and with the 1zz TB. Took it for a test drive and it did just fine :) so I guess this adventure is finally over and I'm ready to move on to my Turbo adventure! Thanks to everyone who helped me out this past year with this issue!
Old 05-29-2013, 01:17 PM   #36
TOLMACH
Drives: soarer
I remember couple other threads where vacuum/BOV/piping was the issue
Will double check everything when installing my turbo .. vacuum seems important ))
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 04:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
AEM FIC to replace CamCon cc101 ?? vten Forced Induction Forum 26 08-04-2012 08:38 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
