![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
oil filter removal tool.
I am interested in obtaining an oil filter removal tool for my wifes Yaris. 2011 model, the 'new' Yaris. 1.33 petrol engine. (1NR-FE). I understand these are only obtainable from the USA. Could anyone tell me the manufacturer and the part number please? An indication of price would also be useful! If anyone knows of a supplier in the UK then that would be most helpful. Thankyou.
Regards Geoff Peace. |
You have a few options:
You can either go with a 64mm x 14 flats socket type tool: Assenmacher Specialty Tools TOY 640 (I believe readily available in Europe) Toy640.jpg CTA A265 (sold by some Toyota parts stores here in the US) CTA a265.jpg or a type which catches the fingers on the oil filter housing: http://www.ebay.ca/itm/Toyota-Lexus-...-/321028758236 Custom.JPG
#3 | |
The 1NR-FE does not have a can type filer. It has a housing with an insert that goes inside of it, so the filter tool is not one of the typical off-the-shelf ones and the size does not vary. It is 64mm x 14 flats. This is what it looks like: 1NR-FE Oil Filter.jpg
#4 | |
Mr. 155 and climbing
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
I have a Pure Power filter for the Yaris, which is reusable - although I only use it every other oil change, because I hate taking the time to clean while I am changing the oil. ![]() http://gopurepower.com/site/products...lt.asp#FILTERS Pure Power manufactures the K&N reusable filter as well: http://www.knfilters.com/oilfilter.htm
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#6 | |
#7 | |
#8 | |
Very good. If you want it sooner, let me know, and I can ship one to you.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Get the Assenmacher toy-640. <<<I highly recommend it. It should be right around $20 USD. It works for both the plastic and aluminum toyota cartridge housings. you need a 24mm socket/wrench on the end of it, but it does the job. It's aluminum, but quality made.
2 things, once the cartridge housing has mated fully with the engine side, stop tightening. it doesn't need to be super tight, just flushed and maybe tapped once. check with CTScott for the appropriate torque specification if you wish. Second thing, remember to remove the tool once you finish using it, it blends into the engine being dull grey aluminum and all lol. Many a lube tech at my job has had to purchase more than one of these tools.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#11 | |
#12 | |
#14 | |
#15 |
The Scion Xd has that plastic oil filter cover too. Not a big fan of it....
Never take eyes off opponent - Bruce Lee |
#16 |
Crazy Russian
Drives: 2007 Yaris RS Join Date: May 2013
One of the best Oil Filter removal tools is from Channellock.
You can remove any oil filter. |
#17 | |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
