Old 05-31-2013, 01:39 PM   #7
Originally Posted by poldenais View Post
HI sorry, still never got this working,
Got the Acc fuse checked under the wheel and also I checked the Dome fuse under the bonnet. I got the power checked coming into the radio and there is no power so it doesnt seem like the radio unit itself..
Please any other suggestions please?
The radio gets constant power from the 15A DOME fuse which is in the under hood (bonnet) fuse box and gets ignition switched power from the 15A ACC fuse which is located on the face of the fuse panel under the dash, on your 2000.
If neither of those two are blown, I would pull the radio out and check to see if one of the connectors is loose on the back of it.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
Power Lock button?? cyberfrogg DIY / Maintenance / Service 25 03-26-2009 10:16 PM
More power, with a push of a button?? leasaunce Performance Modifications 36 08-20-2007 01:59 AM
