![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
LED turn signals
Does anyone know if 7507a is the ONLY bulb that would work for the yaris 06-11 ?
I tried to find some good looking powerful 7507 led on ebay but so far nothing is good, can i use other 7443, 7440 or any other etc? thanks |
anybody?
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
I use 1156 (P21W) bulbs on mine.
I had to file off one of the bayonet lugs so it could fit though. No problems so far. |
does it matter which side you file off the lugs?
btw, what resistor did you use? same specs for front/back?
Problem, officer?
It doesn't matter.
![]() No, I don't install resistors. That would defeat the purpose of using LED bulbs (lower energy consumption). But if the hyper-blinking does bother you, you should look for a turn signal flasher relay for LEDs.
oh i see but in truth i buy the LED for looks, not lower energy consumption, the amount of energy saved is negligible lol
| Projectors retrofit, black reflectors and dimmed front turn signals | my2sense | General Yaris / Vitz Discussion | 11 | 06-20-2012 11:39 AM |
| DIY: Adding LED turn arrows to side mirrors | my2sense | DIY / Maintenance / Service | 10 | 05-28-2012 02:16 AM |
| Green 24 LED Turn Signals 7440 | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 15 | 08-01-2010 11:04 PM |
| Are rear red turn signals planned for Yaris as well ? | 77W | General Yaris / Vitz Discussion | 38 | 02-22-2010 06:41 PM |
| led turn signals.. | marcus | Cosmetic Modifications (Exterior/Interior) | 6 | 03-16-2009 08:49 AM |
