#1 | |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Same manual also states to only use 3/2/L for engine braking or for short period of powering the wheels, but not for extended use (aka regular driving). My understanding of the statements of the user manual so far is that 3/2/L gears are there as an option to take advantage of more controlled engine braking and for emergency manual gear selection, in case the transmission goes bad, you can still manage to drive to your destination/safe zone/repair shop with a lower gear that won't strain the damaged drivetrain too much. I don't think as of now that you should select any of the 3/2/L instead of OD for driving, as it would be the equivalent of driving a manual transmission in a single gear with the engine struggling for staying in the ideal RPM range non-stop. That's how I understand it for now.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
It really depends on what you want. Leaving the transmission in D will allow it to select the most economic gear for the speed you are travelling. Putting it in 3 will lock out the overdrive 4th gear, providing slightly quicker acceleration and more engine braking while using more fuel.
What is more important to you? Performance or economy?
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
