![]() Drives: Yaris 4dr 2008 Join Date: Nov 2008
After almost 2 years of having a once in a while cold problem, but it was mostly running fine, lately it happened more and more, ECU started again to throw codes, high idle...
So I took off the ECU and measured resistance between pin 97 and the CLT sensor found that it was bouncing around, I opened the ECU connector since I had resistance to vary by touching this aera, I pulled hard on the wire (when they are broken inside the insulation won't hold), nothing this is a very good wire, I don't have the tool to release the connectors, but now I measure 0 ohms all the time, so I have put it all back together and since then, it runs perfect, I think it may have been a badly crimped connector (insulation not totally pierced), I hate when I don't find evidence of the problem. |
| Need advice on head unit settings | chewychewbacca | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 03-18-2011 06:54 AM |
| General service/maintenance advice | dweaver3481 | DIY / Maintenance / Service | 2 | 03-14-2011 11:06 AM |
| Ordered some wheels, need advice on tires | 47_MasoN_47 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-21-2010 04:56 PM |
| Yaris 06 T Spirit advice needed ! | nocturne_sa | General Yaris / Vitz Discussion | 1 | 01-03-2010 05:24 AM |
| Good advice for new car owners... | YarisSedan | General Yaris / Vitz Discussion | 10 | 04-15-2009 03:43 PM |
