Drives: 2008 Yaris 4 door Join Date: Nov 2012
Turn off alarm without remote?
Hi, I have an OEM alarm, but I don't currently have the remote, just the key. Turning the key and opening the door sets off the alarm. How do I use the car without the remote?
Thanks! |
The key should work fine if it is really the OEM alarm.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Hi CT Scott, i think it's the TVSS you guys are referring to. If that's the case i would also ask the same question as we are provided with only one factory wireless lock/unlock key. the rest are all just plain keys.
i was worried if i lose THIS key someday, and only have the spare in my wallet, the doors will open, but it will set off the alarm, and won't start the car. (no key immobilizer just the TVSS enine immobilizer) how do we bypass this? thanks! |
#4 | |
With the remote key for the TVSS, like the TVIP, the non-remote key is still supposed to turn the alarm off when then door is manually unlocked with the key. Also, you can purchase additional remotes and use the procedure posted in another thread on here to make the system learn the new remote(s). The transponder key has to be programmed into the ECM by your Toyota dealer, since the Toyota service tool is required to do so.
tried to find anything about TVSS, apparently this is the only one and the reason is stated here by you CTScott. I forgot to thank you before for your response here BTW.
I have a question, using the link below, i found a TVSS module. apparently, it doesnt work. At step 5 of the every procedure, the LED doesnt blink so i can start with the rest of the steps. What am I doing wrong? Or is it not going to work for ours here since it is not a Eurppean Yaris? If you (Scott) or anyone can rewrite the first 5-6 steps in layman's terms i would really appreciate it. The 'reconnect batt negative cable' in step 2 and 'insert key into ignition cylinder' (where? lock only or ACC?) just got me baffled. Thanks YW! https://www.google.com.ph/url?sa=t&r...47244034,d.bmk |
![]() Drives: 2002 3Dr Gs Join Date: Jul 2013
If you insert the key into the ignition with the alarm going off and turn it to the 'on' position the alarm will turn off after 30 seconds. As the alarm is only armed by the keyless entry remote it should not be an issue after the first time the car is opened with the standard key.
| Tags |
| alarm, remote |
| Using a relay for remote turn on | jessewilliams | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-26-2012 01:27 AM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
| checkmate burglary alarm and remote sart 4/s | deadworld | Items for Sale by private party | 2 | 09-09-2007 11:25 AM |
| toyota vip rs3200 alarm system and key with integrated remote | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-16-2006 06:02 PM |
