![]() ![]() ![]() Drives: Black 07 Toyota Yaris Sedan Join Date: Oct 2009
FS: Pair of Black Liftback Power Mirrors
I have a pair of power mirrors for the yaris liftback black. Pretty good condition.
$60 Plus Shipping Will trade for nst water pump or alternator pulley, intakes or some sort of performance parts. Shoot me offers. ![]() ![]() ![]() ![]()
![]() Drives: 2009 Yaris Hatchback Join Date: Apr 2011
Will it fit 09 yaris hatchback?
Pm
As an FYI, if you have a liftback without power mirrors, they are pre-wired for them, so all you need is the mirrors and the switch (which runs under $50 on ebay).
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Hmmmmmmm.....do you have install instructions, Scott?
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Probably plug and play to be honest if it's already wired..
I have a bunch of pics from when I installed a set on Crashy2, but it is quite easy to do:
Pop out the plate by the dimmer knob, insert the switch, and plug in the connector that is taped to the top area of the under dash fuse panel. Remove the door panel, remove the two nuts that mount the manual mirror, feed the mirror harness through the door, plug it into the connector that is sitting beneath the door panel, and put everything back together.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
hi scott/OP, would you know if they can fit (or easy retrofit at best) sedans?
#9 | |
Theoretically they should be an easy retrofit for the Sedan as well. The thing you want to do is to check for the presence of the connector which will plug into the switch. If that is present then the wiring is present. If it is not, then it is not as plug and play as it is with the liftbacks.
It won't work man, sorry. The reason i'm selling is because i bought these thinking i could use them for my sedan and there are too many differences to have these retrofitted to the sedan.
Bump
I'll take 'em if you'll bring 'em.
![]() Drives: 2009 LB Join Date: Jul 2009
Are these sold or still available?
2009 Yaris LB Carmine Red (Very manly thank you) 2006 Porsche Cayman S 2008 Honda Pilot EX-L 1996 Ducati 900SS |
#14 |
It's Quacktastic!
Drives: '07 Yaris Hatch Join Date: Aug 2010
I will PayPal immediately if these are still available..
#15 |
Still for sale?
Never take eyes off opponent - Bruce Lee |
#16 |
It's Quacktastic!
Thanks for the update! :)
| Is concenience package and power package the same thing on liftback ? | YarisBlazer | General Yaris / Vitz Discussion | 4 | 07-21-2006 11:58 PM |
| Liftback with power package | rchowelljm | General Yaris / Vitz Discussion | 14 | 06-23-2006 10:51 AM |
