![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
Can someone share some experience :)
Hi guys like i mentioned in the other thread... My car seems to be making a small pop noise when i hit a bump or take a sharp tight turn towards the right.. I got the car checked a second time and the guys at 191 motorsports found nothing wrong with the car.. but also mentioned that when i drive the car in the rain on a rainy day, there is no more pop. Anyone experienced this ?
![]() Car has 27600 kms |
やりすぎだ~
It must be the Beiber effect.
common bro be serious....
Check out this thread on the broken control arm bolt issue that can occur if the bolt corrodes:
www.yarisworld.com/forums/showthread.php?t=27658
Hi CTScott
those bolts are all ok... car was checked twice by..
OK - In that case, it could be something wedged against the dust shield for one of the front calipers, a CV joint that is on its way out, a bad lower ball joint, etc.
The CV joint would sound more like it..
Can it be the shock ?? I dont know how the top plates work on this car, but when i pop the hood, i can see the shock, but there are now screws holding it. All i see is a black rubber about 3 inches in diameter.. How do you remove the shock on this thing... anyways im scheduled wednesday morning for another road test..
#9 | |
Thanks CTScott , ill let you know when im done on wednesday.. i know im hearing a pop coming from the drivers side, it does not do all the time.. just so freakin annoying.. grr
| not so good of an experience | Schutzhund3 | General Yaris / Vitz Discussion | 42 | 12-22-2011 09:46 AM |
