![]() Drives: 2008 Yaris LB/MT Join Date: Oct 2008
TPMS Follow-up
Here's a tidbit that folks with a ScanGuage II might find helpful. When the Toyota mechanic went to initialize the new TPMS sensors, the car kept throwing a TPMS error and the light would come on. He even reset the sensors with the SC_II disconnected but the error would return as soon as he plugged it back in. We finally found that if you leave the SC_II disconnected for the 7-10 miles it takes to lock in the sensor ID's, then plug the SC_II back in, then all is fine. No more TPMS errors with or without the SC_II
Cheers, Paul_F
Cheers, Paul_F |
| Tags |
| tires, tpms, wheels |
| TPMS questions | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-02-2013 05:18 PM |
| DIY - - -TPMS work around | rningonfumes | DIY / Maintenance / Service | 6 | 03-03-2011 08:11 PM |
| TPMS light on after swapping 1 tire from different car | nvidiaxtc | DIY / Maintenance / Service | 5 | 02-02-2011 09:45 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
