Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
Does this look like a good turbo build?
Yeah. It's been less than a year since I sold my Yaris. The Fiat wasn't what I thought, the Celica I'm driving now is aggravating, and I can't afford an Abarth 500.
So, I may be looking to get back into a Yaris and I found this gem. http://www.jabaay.com/2009-Toyota-Ya...-60438/4665990 I had gotten places with my old black Yaris, but didn't get into turbocharging or any serious engine work. Was wondering if any of you gurus can tell from the pictures if this car is a quality build or even if it previously belonged to somebody here. It looks like it has the MI center armrest as well, so whoever owned it was aware of MI, if not YarisWorld. Thanks again and it's good to see some of the regulars still causing trouble. EDIT: Didn't mean to crosspost, forgot about the Forced Induction forum.
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
That is not a TRD turbo kit- It looks like a generic aftermarket one (Zage, etc.), but it looks pretty well done, and $9K is a good price for a non turbo 09.
Pirate Yaaaaris
I figured it wasn't the TRD kit, but it seems like it has a few other parts and looks pretty well put together. I need to run the VIN though before I even think of e-mailing that dealer.
For reference, I paid $8585 OTD for my stock 09 back in January 2010. Did the lowering, wheels, headlights, intake, shift kit and stereo all myself. Only thing I think this one needs is Garm's center exit exhaust. ![]() -C
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Is Garms Yaris still for sale?
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Pirate Yaaaaris
I think so. His thread in FS hasn't said it's sold.
His car is a little too extreme for me, though, when I stopped and thought about it. I do 28 miles of interstate one way to work, usually while hauling a hatch full of pharmecuticals. I need my interior and A/C. There's also the little problem of his car being 2500 miles away from me. ![]() -C
Looks clean to me, good job on the fuel lines. Any problem with smogging in your state?
#7 | |
Pirate Yaaaaris
-C
Toyota Direct Injection (TDI)
![]() It's definitely not TRD. |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
^ /concur
yea, that would require the fuel injectors to be directly injecting into the cylinder at the last few degrees of the compression stroke, just before the power stroke. it is more common in diesel engines and i havn't seen a yaris with direct injection in the United States so someone clearly made a booboo or doesn't know what they are talking about.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
This is a good reason to steer clear of this car.
Pirate Yaaaaris
Because of what a dealer wrote? Dealers screw up all the time on listings. I'm not asking about what the dealer wrote, I'm asking for opinions based on the actual pictures. I already deduced that Direct Injection and such wasn't the case.
We already know TRD doesn't make a turbo kit for the 1NZ that looks like that, and we already know that no 1NZ is DI or we would've had horror stories about carbon build up after it being in the market since 2003. -C
Why not ask about what the dealer wrote. You shouldn't have to "deduce" anything. If they don't know about the car's injection system, they probably don't know very much about ANY of the car.
So, how about some real questions then. What turbo is it using? Is there any play? How many miles on the turbo? What management is being used? How and where was the car tuned? Are there dynos? How much power is it making? What boost level is it running? What is the compression in each cylinder? What do the plugs look like? And so on, and so on.
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
That Yaris is definitely Brian's (pimp_my_yaris). I'm a mixture of bummed and curious to see why he sold it. Looks like he's only been inactive for a month too...
He had a pretty quality build. IIRC he built the engine, did the pump, injectors, rail and regulator (obviously). Here's some more reading: http://www.yarisworld.com/forums/showthread.php?t=29053 Edit: If you have another car and live in GA, there really is no reason to not buy Garm's Yaris if you've been considering it. 8.5k (or whatever it's at now) plus 1k shipping is beyond a steal for that level of performance. Plus, all the problems you mentioned really aren't that big of a deal (maybe ac, depending on how much needs to be done to make it functional). |
#14 |
^ Thanks for that plug. I will add that I know have the carpet and most interior pieces for it as well.
#15 | ||
Pirate Yaaaaris
I don't care that the car sits inside the showroom because it is a quality build. The dealer didn't build the car and the showroom didn't build the car, so sitting in the showroom means nothing to me. WHY is it a quality build? That's what I was hoping to find out. Quote:
, but in the end, far far too hard core for me at this particular point in my life.Also, I don't have a second car to use while his car would be built to my liking for my daily uses. The fiancee uses her car for a 61 mile round trip commute, and we work largely opposite hours, so it's not like I could be dropped off along the way. Trust me. I've thought LOOOONG and hard about that turbo'd beast. ![]() -C
#16 | ||
![]() Quote:
#17 | |
Mr. 155 and climbing
Brian and I talked on the phone I think back in the beginning of August and he mentioned kicking around the idea of moving on from his LB. I am having a blank on what his reasoning was even though we talked at length about options, etc. AFAIK he was actually talking about buying a Vette to build out as it is something he has wanted to do for a while. I know more of why he let the LB go, but they are personal so I won't dig into them. I can tell you that it had nothing at all to do with the LB itself. He loved it, but was ready to move on....kind of like Garm and his LB.
#18 | |
Not to cause a hijack, but I can attest to Garm's LB at both settings as I rode in it back last December while I was in L.A. for work and having both settings really makes life easier it would seem. Run it at 14psi like a woman wearing jeans and sneakers...switch to 24psi and put on the tight skirt n' heels and go super sexy! ![]() I wish that I could have ridden in Brian's LB too, but unfortunately I didn't make it to Chicago in time. I have always wanted to feel the comparison in several boosted Yarii, but really even though the count is going up it still is nowhere close to "mainstream". A double edged sword indeed.
| Vios turbo maybe :) | packetrace | Forced Induction Forum | 14 | 06-18-2012 10:20 AM |
| PETERPOOP's Turbo Build Thread. | PETERPOOP | Forced Induction Forum | 114 | 02-08-2011 10:21 PM |
| HKS turbo for mk1 yaris 1 litre 1SZ-FE | nuttallacpw | Items for Sale by private party | 10 | 01-26-2011 05:03 PM |
