Old 11-26-2012, 06:14 PM   #595
I would suggest some way of warming up the engine before driving to prevent possible damage to the cylinder walls and pistons.
LOL, like sitting in the car and starting it?
Old 11-26-2012, 08:00 PM   #596
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
that is what i do, wait until the O2 sensor is warmed up enough to start working (130 degrees Fahrenheit) then easy down the road a few miles, wait at a light, easy down the road toward the interstate, get on the interstate, and by then i'm about 175 ish, so i can give it some gas to merge onto the interstate. and laugh as i hear the loud roar as my exhaust goes through the Megan Racing header, and out the DC Sports Muffler. oh the sound of a little 1.5L sounding like a much bigger car. just kind of make me smile, now if only I had a turbo as well.
Old 04-17-2013, 10:50 PM   #597
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Well for a long time now I have been trying to tune my FIC for 20psi. I have never been able to get it quite right. Because of the difference in fueling from the factory computer at say 60% throttle opening at 10 psi compared to 100% throttle opening at 10psi. If tuning for 100% throttle you will be very lean at 60% throttle. If tuning for 60% you will be pig rich at 100%. I have tried to find a happy balance but its just not possible. I have turned the boost down to the 12-13psi range. This is a little bit more managable. To get the full potential of this built motor it will need a stand alone. Its just more then I want to spend at the moment.
Just curious how does the boomslang hook up to the AEM EMS and the factory computer at the same time. I now the power steering still needs to hooked to the factory computer. Also can I still use my A/C. Anyone know?
pimp my yaris is offline   Reply With Quote
Old 04-20-2013, 02:12 AM   #598
Focus_Sh1ft
Focus_Sh1ft's Avatar
Oh man, you must be itching to get a standalone knowing you have a built motor you can barely make use of
I can't speak for how the boomslang would work in that regard. I can't imagine they'd completely disregard usage of the stock ECU because you would be losing a huge amount of functionality.
This may not be the best example because the wiring is custom but - in my tC, both the Motec ecu and stock ecu are used. The Motec really only takes control over what's necessary to manage the engine. It also has configurable inputs for a huge slew of things. I'd imagine any decent standalone would have the same.
As for A/C - I believe the way I have it handled is you flip a switch (NOT the oem one), the Motec sees this as an "a/c request" then powers a relay which is connected directly to the a/c clutch. The stock ecu is completely bypassed.
Old 04-20-2013, 11:21 AM   #599
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by kou View Post
I think you got that backwards, if stuck closed it would build up to much boost stuck open it would not build any boost.
Oh yeah.... haha
Old 04-20-2013, 11:25 AM   #600
fnkngrv
fnkngrv's Avatar
I am wondering this as well. I REALLY want to stay away from AEM again, but may end up having to go that route. I know there are plenty of folks that swear by them, but I have had too many issues to not be leery with their products. So I would like to know whether or not I would still be able to use my Bslang or if I will have to pick up a new harness also.
Old 04-20-2013, 11:28 AM   #601
fnkngrv
fnkngrv's Avatar
During our phone conversations I was afraid of those issues you are seeing with the FIC just not being able to cut it. To me the FIC is really just a hobby box with how intelligent and restrictive today's ECUs are from Toyota. Best to just bite the bullet and go full standalone otherwise you are just wasting your money every time you start your car rolling down the pavement.
Old 04-20-2013, 01:22 PM   #602
The FI/C is perfectly fine up to a point. When you have to mess with more parameters (like timing) to support more boost, you need a better box.
The Boomslang for the FIC will be completely different than the one for the EMS, pretty sure about that.
Old 04-20-2013, 02:37 PM   #603
fnkngrv
fnkngrv's Avatar
That is what I was afraid of Makes sense, but really sucks. Money down the drain.
Old 04-20-2013, 02:56 PM   #604
I can't imagine the FIC end being the same as the EMS end. The Toyota end is probably the same.
It's not a waste if you sell the harness to an FIC owner, or sell it as a package with the FIC. It costs money to build a race car.
Old 09-27-2013, 11:24 PM   #605
pimp my yaris
C'est la vie
Hi guys I just wanted to say this will be my last entry on Yaris World. I had a great time on this forum and chated with some great people and got some great info. I sold my turbo Yaris to carmax in Schaumburg. They auctioned it off and Ive been told from another YW member that it has turned up 4 sale in merriville In.
I used the money as a down payment on a 2002 Kenne Bell supercharged C5 Corvette. With 26K miles. I love it. I also loved the Yaris and it was a great car. It did more then it was ever designed to do. With new pistons and rods with a turbo it cruised to Quebec Canada and Miami several times with two motorcycles in tow. With 12-14 pounds of boost with no problems and never burning oil. Good luck to the next owner. I hope they put a standalone ECU and get the most out of that built motor.
Old 09-27-2013, 11:28 PM   #606
pimp my yaris
C'est la vie
If you want to check out my old ride and the fastest Yaris I have ever drivin.
http://www.jabaay.com/2009-Toyota-Ya...-60438/4665990
Old 09-27-2013, 11:30 PM   #607
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Hahaha some guy on here is looking to buy it!!! No one knew who built it or how it was done. Now we have the owner! Haha. Small world.
Old 09-27-2013, 11:32 PM   #608
pimp my yaris
C'est la vie
Old 09-27-2013, 11:39 PM   #609
SAV912
Pirate Yaaaaris
SAV912's Avatar
Cool deal. This is what I was looking for. A turbo Yaris is something unique enough that I figured somebody on YW HAD to have owned it or at least knew of it.
Gotta say, though, can't blame you an ounce for turning it in for the Corvette. That thing must be a beast.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 09-28-2013, 11:26 AM   #610
Focus_Sh1ft
Nice vet! Good luck with everything, you'll be greatly missed.
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
