Old 10-16-2013, 02:47 PM   #1
silentassassin
Drives: 2012 Toyota Yaris
RPM question
Iv noticed while driving on the highway, my RPM's are around 3200-3500. Now my question is will driving at these high RPM's ware out the engine faster? Because other cars i drive are less than this. Thanks for the help.
silentassassin is offline   Reply With Quote
Old 10-16-2013, 02:51 PM   #2
That's about the correct rpm range for ~70 mph or so, and is typical of engines of this displacement.
Were your other cars 6 or 8 cylinders? An 8 cylinder can cruise along at the same speed while only spinning around 1600 rpm.
Old 10-16-2013, 04:28 PM   #3
jayeh
Drives: '08 Yaris LB
It's a toyota. It loves to rev. Don't worry about it.
I found it pretty alarming at first too.
jayeh is offline   Reply With Quote
Old 10-16-2013, 10:24 PM   #4
silentassassin
I found it alarming as well, but i only had the car for 2 weeks or so. So i guess ill get used to it. Also will reving it more hurt the mpg? thanks again for all your help guys.
Old 10-16-2013, 11:02 PM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That sounds a little high to me. Is your Yaris an automatic? Mine does 2,600rpm @ 60mph on the freeway with a stick.
Greg
Old 10-17-2013, 09:59 AM   #6
silentassassin
Greg
Mine is a automatic. but i'm going around 75-80mph i live in Florida so the highway speed is 70mph.
Old 10-17-2013, 10:00 AM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
LOL you are never going to be driving at 1200rpm@60mph :P
not like old GM cars..
my old swift with a 3 spd auto trans did 4000rpm@70mph.
Old 10-17-2013, 04:16 PM   #8
jayeh
Nope, although the mpg drops the higher you go obviously.
Remember that similar cars get the same mpg as the Yaris (or lower) and they all have 5-6 speed automatics too!
Greg
The AT is definitely a bit higher than that.
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
