Old 10-28-2013, 07:38 PM   #17
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
My next course of action is to remove to LSD from the broken transmission , hopefully it is ok. I have my original transmission sitting on a shelf, and it is good. The broken one had taller/Yaris gears. I would like to a transmission cooler setup, just like our time attack tC. Basically takes the oil from the drain plug, pumps (elecric pump) oil through cooler , then back through oil squirters tapped into trans casing aimed at each gear.
Ptuning.com
Blown_xa is offline   Reply With Quote
