![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
CTScott Pls help - ELM 327 OBDII BLUETOOTH ADAPTOR
Hi,
I am looking to get an OBDII Bluetooth Adaptor to communicate with my Toyota Belta (Japanese manufactured) via android/IOS, but I've heard that the ELM 327 OBDII bluetooth adaptor is not compatible with my Japanese made Belta. Could anyone suggest a compatible adaptor that I can order from ebay for my Belta. @CTScott would appreciate if you could help me out. Thanks Tyrone |
I am not sure that any of the cheapy ebay ones will work since they need to support M-OBD, as opposed to OBDII.
Oh; actually my relative is coming down from Toronto so I was thinking of asking him to get it for me by ordering thru ebay.
#4 | |
The legal version of it, which definitely works with TechStream and M-OBD based Japanese Toyotas is the Drew Technologies Mongoose (but it is $495, as opposed to $22 like the Chinese clones). I personally own the Drew Technologies one and it works with a Japanese Vitz ECM that I have on hand. It does require the Toyota TechStream software, which legally requires a subscription to use ($55 for a 2 day or $1095 for a yearly subscription). There are pirated copies of TechStream floating around on the internet, but like with the Chinese clone of the hardware, there are risks and legal concerns in using them.
Thanks for the info.
I guess will have to wait for another option to come by. |
#6 | |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
That way, I can be almost a 100% sure that even if there was malware inside it would not hurt my host computer ;) It has worked well for me up to now with my XP9 and a P1. However, do not expect it to work with cars from other manufacturers. It won't help you at all, but if someone ist curious: EOBD works with the ELM327-clones |
#7 | |
Embracing Curves
Okay, maybe my version is too old ;)
I chose the CF-18 because it is rugged enough to put it on top of a motor whose belt you change during a snowstorm to look how to put it in right :D |
![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Hey Tyrone,
I know why it doesn't work. I have the same problem. I have a JDM Vitz and the ELM327 wont recognize the car. Its because JDM cars don't follow standard OBD2 protocol, they follow JOBD (Japanese OBD) Now, I think the ELM327 can read the code, its just the software cant understand it. So far I haven't been able to find a software that could do it. I tried the same adapter on local market Toyota's and it works really well. This is the only disadvantage of a JDM car I guess. Some of the standards are strictly Japan style. Hope this helps. |
![]() ![]() Drives: Yaris Sedan Join Date: Dec 2012
I bought a cheapy ebay ELM327 for $12 and it worked on my 07 Yaris with android Torque Pro app. I got sensor values like fuel flow, coolant temp, etc.
It actually came with a CD with programs to record but I haven't tried it (since I only wanted for Torque Pro) |
| ELM327 Bluetooth OBDII Scanner thing | JudgeM | DIY / Maintenance / Service | 29 | 10-13-2019 01:40 PM |
| Tomtop ELM327 Bluetooth OBDII Reader | Betrivent | General Yaris / Vitz Discussion | 31 | 06-12-2011 05:22 PM |
| Bluetooth OBDII | WolfWings | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 09-01-2007 04:44 PM |
