Old 10-31-2013, 03:23 PM   #18
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
CLIP THE SIGNAL ?
CUT THE WIRE IS THAT OR ?
I HAVE THE CRAPPY SQUARE LED STYLE, RADIO.
I HAVE THE MODEL AND SERIAL NUMBER WRITTEN DOWN, AS THEY CHANGED THE UNIT A FEW WEEKS AFTER I BOUGHT IT, AND THEY LET ME HANG WITH THE TECH / AN OLD CO-WORKER WHILE HE DID THE RADIO. (old radio said CD IN, even when not in)
NO WRITINGS ON SPEAKER MAG IN TRUNK.
BUT, YEAH IT SEEMS NO MATTER WHAT SPEAKER, I WILL NEED TO GET ME AN AMP. I HAVE A 2 CHANNEL, BUT WANT A 4 CHANNEL.
SPEAKERS, I WANT POLK AUDIO, BUT AMPS, I AM AFRAID POLKS MAY NOT BE GOOD ENOUGH IN THE AMP DEPARTMENT, AS MY PSW10 TOOK A DUMP 3 YEARS IN ON MY HOME AUDIO SUB AMP, LUCKILY, THEY GAVE ME A FREEBIE AMP AND IS WORKING SO FAR.
POLK'S, LOVE THEIR AUDIO QUALITY AND CLARITY AND POWER TAKING ABILITIES THOUGH. I DO KNOW, WITH FACTORY SPEAKERS, THE STOCK RADIO STRUGGLES, BUT THE STOCK RADIOS TUNING CAPABILITIES ARE GREAT (CAN GET GREENVILLE RADIO STATION IN CHARLOTTE AREA)
10 watts Rms is not written by the hand of god. You can have variations. They have an integrated model, one that has navigation (tom tom). Or even the Pioneers that come in Scions can fit.
Pull your radio and get a model number. May even give rms. You speaker is rated as well. When I pulled my speaker I believe if I remember correct it had the rating on the magnet.
Max is usually double the Rms. So 20 watts max.(uneducated guess)
Major thing to remember is not to clip the signal.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
