Old 11-14-2013, 03:14 AM   #8
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Originally Posted by ivanstepul View Post
Im lowered 2 inches and the ride is too stiff. if I get larger sidewall tires will that help maybe like a 205/50/17
Lowered by 2inch... You'll get slight rub with 205/45/17. if you insist for 205/50/17, you gonna tear off your fender inner shield when you rub harder.
If your problem is really being too stiff, my advise is to revert back to stock springs and go OEM 205/45/17. If you wanna to have BEST of comfort and some look to remove the tires gap, go for 205/50/17.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
16 inch or 17 inch rims? helladopebev Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 11-19-2013 02:56 AM
Looking for 15 inch stock steel rims hop Canada 2 01-21-2010 08:18 AM
