Old 12-22-2013, 03:22 AM   #4
muncedog
Drives: Vitz 2002
So its around 120K km, I have now fixed the window ( loosened motor bolts, gave the gears a gentle tap with a hammer... I think It might have gone of the end tooth or sat closed for weeks on end and seized...
I think the drivers door lock is stiff as the inner door housing is bent and putting pressure on the lock bit... For this reason it takes a few presses of the key to lock the door!
I will take it to a garage to get the bearings done!
Given how much of a pain it was to put the inner door back on for the driver (little plastic clips snapped...) I won't bother adjusting/replacing the springs in the other door handles!
muncedog is offline   Reply With Quote
