Old 12-24-2013, 12:42 PM   #1
EchoBob02
Bobby T
Drives: 2002 Toyota Echo
Cool 1nzfe throttle body swap and fitment questions
Hey everybody I'm new to The forum, I've got some questions about doing the throttle body swap. I went to my local parts yard and found plenty of cars with the normal throttle body to swap. My question is, I found a few corollas or camrys that have the 2.2 in them. It has the same 3 bolt flange so it should bolt right to the intake of the 1nz, is this throttle body from the 2.2 bigger than the other throttle body people are using over the stock one? And if it is different, in what ways are they different and will it be a better swap? Pros and cons please! Thank you.
Ps I am trying to locate pulleys for the crank,cams? Not sure if they have pulleys for the cam considering it's a vvti engine. Also trying to figure out what I can do about the plastic intake manifold, is there an intake I can modify and or swap into the echo? If not who makes sheet metal Intakes?
EchoBob02 is offline   Reply With Quote
Old 12-24-2013, 12:47 PM   #2
First off, you have an Echo, so you have a cable throttle right? If the Corolla TB is the same flange AND the cable linkage is in the same place you might be able to swap it.
You'd want an xB pulley, your car has a dual belt crank pulley (2nd gen Yaris has a single belt pulley). I sell a few brands of light pulleys for the xB/Echo. I don't know of any cam pulleys.
Intakes I'm not sure about, as again yours isn't the same as a 2nd gen.
Old 12-24-2013, 05:31 PM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
There's a guy in Australia running a larger Corolla three bolt cable operated throttle body on one of my tooter intake manifolds. This is a pic of his setup...
Old 12-27-2013, 06:14 PM   #4
EchoBob02
Bobby T
Ya the tb I looked at is a cable tb. I'd like to get more air in and more air out. I've got a dc sports ceramic coated header which made a difference.
(Tooter)- how much for one of those intake manifolds and what kinds of throttle body's have you seen used on the 1nzfe successfully with your manifold.
(Cali yaris)-- I know I have an echo. How much are your crank pulleys?
Old 12-27-2013, 07:47 PM   #5
tooter
play every day
tooter's Avatar
They're $595 including shipping.
None are available at the moment as the machined parts to make them won't be ready until next year. I have one manifold that's ready to be built.
The tooter manifold accepts all of these throttle bodies:
46mm 4 bolt throttle body ( electronic drive by wire)
55mm 4 bolt throttle body (electronic drive by wire)
51mm 3 bolt throttle body (cable operated)
Greg
Old 12-28-2013, 08:18 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Tooter, they're still 595 WITHOUT the throttle body adapter? he wouldn't need one.
Old 12-28-2013, 05:41 PM   #7
tooter
play every day
tooter's Avatar
Good point, Blue.
He didn't mention which throttle body he was going to use. If it's a three bolt cable operated throttle body, then it's $100 less without the adaptor.
Greg
Old 03-22-2014, 08:07 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Mild thread necro:
What's the thread on the TB studs? M6? M8? The web isn't being useful tonight...
*edit
I found a Matrix site claiming them to be M8x1.25. Can anyone confirm this?
Old 03-23-2014, 12:56 PM   #9
Toy_Yoda
Drives: 2006 Scion xb
The info on the Matrix site is correct. My first gen XB uses 8mm x 1.25mm.
Toy_Yoda is offline   Reply With Quote
Old 03-23-2014, 10:14 PM   #10
CrankyOldMan
Thanks. I made a first pass on machining the adapter this weekend, but didn't get to the drilling/tapping or the gasket channel.
Old 03-29-2014, 11:33 AM   #11
CrankyOldMan
Sadness: the holes on the 1ZZ TB won't fit an M8 bolt. Must be M6 studs. Two choices: make a new flange, or bore the TB holes...
Old 03-29-2014, 11:51 AM   #12
Bluevitz-rs
Just drill out the TB if there's enough material.
Old 03-29-2014, 01:43 PM   #13
CrankyOldMan
I've got enough material to make a few more, but I'm going to stop by the you-pick junk yard and see if there's still a TB on a Vibe/Matrix for a spare. I also need to make some adjustments to the dimensions of the gasket channel, so it's probably best if I just make another.
Old 05-01-2014, 08:02 AM   #14
Bluevitz-rs
you want this one -->eBay link
And no other manifold fits. You need to bore the stock manifold to size or get Tooter's custom one.
1zz Throttle body review/tips Black_griffin6 Performance Modifications 154 11-18-2021 03:35 PM
