Old 01-06-2014, 11:16 PM   #7
Originally Posted by alagappan the proud View Post
I never did try to remove it. The car ran fine after a small hiccup when starting. After I figured out what likely happened, I thought the damage must have already been done and that the piece probably came out of the exhaust upon starting.
What do I need to look for as far as damaged valves, etc, that could have occured?
Thanks for all the help...
It probably has exited at this point. If it did any valve damage, you would likely still be feeling it. You could do a compression test to verify that that cylinder is still OK.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Spark plug replacement vinny121 DIY / Maintenance / Service 3 08-29-2013 12:25 PM
Spark plug change . Dc1011 DIY / Maintenance / Service 2 01-29-2012 01:55 PM
Checking engine performance after spark plug change phantomlord DIY / Maintenance / Service 6 06-22-2011 04:38 PM
