Old 01-08-2014, 08:54 PM   #3
Roxy1186
Drives: 2008 Toyota Yaris Hatchback
It is definitely still in the car. Things that go down the rabbit hole there can end up right below the center of the cluster or can make their way back as far as the ebrake lever. You can remove the center console to gain access. Just remove the 10mm bolt in the cup holder at the rear, and then pop the console.
In the couple of wrecked Yaris that I have disassembled I have probably found at least $5 in change in each.
You need to remove the center console
Thanks for the response CTScott. I should clarify that I meant the center control panel. I'll try to upload a picture here. It fell through the storage compartment on the right side there, left of the glove box.
Roxy1186 is offline   Reply With Quote
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
