Old 01-10-2014, 01:13 PM   #39
Originally Posted by Rodger Wilco View Post
Hey guys I have a similar code on my 2010 Yaris maybe you can help. The code reads: B1901 Open in P/T Squib(RH) Circuit.
Also, the diagnostic computer tester thing I used I had borrowed from a friend and it only had the option for a 2007-2009 Yaris, it did not have database for 2010, I am wondering how much of a difference that would make?
Where do I go from here besides a dealer? I am resolved to fix this thing without spending $$$ at the dealership.
Thanks!
Was your Yaris in a crash? The B1901 code signifies that the driver's side squib is open (which typically means that it popped in a crash). You can verify that by pulling the B pillar lower cover and checking the rectangular block on the side of the seatbelt assembly. If you see orange through the little holes, then it did pop and will need to be replaced.
As far as the year part goes, 2006-2011 are identical as far as SRS codes go.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
