#1 | |
Hopefully the issue is that your coolant temp sensor is actually bad. I have experimented with clusters from other regions and the temperature lights always worked correctly, as the cluster just receives a CAN bus signal from the ECM with the temperature. Definitely not an ECM issue.
#2 | |
![]() Drives: Yaris M2 1.0 Join Date: May 2016
So it looks like everything is working fine. Thanks again, Matteo |
![]() Drives: Toyota Yaris 2006 1.0 VVT-i Join Date: Jun 2016
Hello,
If I want to change my VFD speedometer (Yaris 2006) with one newer from (yaris 2009) - I need also the immobilizer? Thanks, |
| Tags |
| cluster, digital, gauges, intsrument |
| Custom Instrument Cluster LED Color Change Service | CTScott | Items for Sale by private party | 74 | 06-10-2022 01:29 AM |
| Cruise Control - 07/08 Sedan - Instrument Cluster | CB900F2 | DIY / Maintenance / Service | 4 | 02-23-2011 07:03 AM |
| DEAD INSTRUMENT CLUSTER! | yaris2010RS | General Yaris / Vitz Discussion | 21 | 02-24-2010 12:06 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
