![]() ![]() Drives: 07 hatchback Join Date: May 2012
Has any one put this on with the stock airbox yet?
play every day
I don't think anyone has so far, but I'm pretty sure that it will work because the stock rubber intake hose is pretty flexible, and the spacer doesn't move the throttle body closer or farther away from the air box, but moves the throttle body sideways in relation to the air box.
My tooter intake manifold also relocated the throttle body sideways in relation to the stock air box, except that it also moved it closer, so I trimmed a couple of inches off the hose and it was still flexible enough to easily make the sideways offset. ![]() If anyone does use their stock air box, please let everyone else here know how it goes, as that's useful information. ![]() Greg Last edited by tooter; 03-18-2014 at 11:01 PM. |
It does make the heat shield on the K&N SRI (Typhoon) almost unusable. Fortunately for me, one of the brackets on the shield is no longer connected, so it allowed for some flex. I do, now, have a rattling sound because of this. haha.
You can see that the intake pipe is no longer in the center of the heat shield passageway and is actually pushing the heat shield forward.
![]() ![]() Drives: 2009 Toyota Yaris Sedan S Join Date: Aug 2009
What is the wrap you have on the K&N intake and mesh around the filter? I have the same intake and am wondering if that helps.
As for the heat reflective wrap, it does help, but only noticeable, for the most part, under conditions that will allow heat soaking.
One fill up since installing the Tooter spacer. After 340.9 miles of my car Tooting along (lol), it got 42.3 mpg. That's a slight improvement from my 40.3 mpg average.
http://www.fuelly.com/driver/07vios/yaris |
#11 | |
play every day
![]() We have only three fillups since the spacer and the overall average is 37.5 mpg, and that's with no freeway driving. Before the spacer, stock manifold and, stock throttle body, I was running the tooter et and the 1ZZ throttle body. The mileage average for 4 fillups was 39.9 mpg but that was with freeway driving. Greg |
#12 | |
![]() As everyone can see in the log book portion, my mpg's are rather consistent from week to week, as I'm usually doing the same driving day in and day out.
Hey got mine installed last night. With the stock air box this is kind of hard actually.
Things that are probably worth Mentioning are that the vacuum lines need extended, the sensor just off the throttle body cannot be mounted back into the boot due to the length of the wires. The coolant hose that comes up and over the manifold is actually long enough on its own, though the lower one does need extended or replaced if you can get it the other end off. Without anything mounting the wiring harness that runs across the engine this might eventually lead to fatigued and broken wires, I will figure out something to attach that to and hopefully re attach the decorative cover |
#14 | |
play every day
![]() Greg |
play every day
Four tooter I.V spacer kits have been sold... and two are still available.
![]() ![]() ![]() ![]() ![]() $265 includes shipping. PayPal: greggabi@verizon.net Or personal check or USPS Money Order to. Greg Mamishian 21444 Entrada Road Topanga, CA 90290 Greg Last edited by tooter; 04-28-2014 at 11:56 AM. |
play every day
bump
play every day
bump
I had to extend/swap out the hose that red on yours, and the PCV hose. I was, oddly enough, able to reuse the coolant hose that goes to the TB.
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| stock scion xa exhaust and intake manifold and others | taman86 | Items for Sale by private party | 0 | 09-27-2012 02:39 PM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
