Old 02-09-2014, 08:59 AM   #19
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
I had heavy 17's on my echo for a little while (one set of tires worth) and I could tell it in hwy mpg too. It went from 43-44 mpg to 35-37 mpg.
Old 02-09-2014, 12:23 PM   #20
Originally Posted by venezbras2013 View Post
Kaotic: cool versions of your Yaris! Question on those 17x7.5 with ET38mm... any issues at all running those wheels? I'm asking because i bought some Enkei GTC01 with ET38mm and was thinking on running the same tire size you run 205/40R17... any rubbing with that setup? what type of suspension do you have? by the way, I have a 5dr hatchback (SE model). Thanks.
Thanks. With those specs, I had some front fender liner rubbing on freeway dips. No biggie. I just let the tires wear out the fender liner a little, then I cut out those areas. I didn't have any issues with the rear until I put 10mm hub spacers . I solved that by rolling the rear fender lips.
Old 02-11-2014, 12:03 PM   #21
Blue09
Drives: 09 Yaris hatch 5spd
Wow thanks for all the posts dudes! Think I'm still gonna go with the 17s since most of my drivin is on the highway so even if I do lose a few mpg not too big of a deal. That said wtf is up with toyota not having cruise control be standard on a car that has power everything else? JERKS! Lol. Not a deal breaker though Im lookin at tocomas now. But im rambling. Thanks
Blue09 is offline   Reply With Quote
Old 02-11-2014, 03:21 PM   #22
imo, cruise control would use up more gas because it'll constantly alter the throttle position to maintain the speed.
Which Tacoma are you looking at?
Old 02-11-2014, 03:27 PM   #23
^ I agree that pulse and glide works better, BUT with cruise control I drive less aggressively, so that's a good thing.
Old 02-11-2014, 11:17 PM   #24
Yeah, I suppose for the lead footed people, CC would work.
Old 02-17-2014, 10:58 AM   #25
Blue09
Well I was thinkin extended cab 4x4 with V6 at first but now I'm leanin towards reg cab 4x4 with the 4 banger but still not sure. Going used in the 2005-2009 area so payments wont be so bad as new with a nice down payment. Wont be my DD so I plan to supe it up with exhaust n maybe a chip n stuff since I already have a good mileage vehicle. Most work itll see will be hauling my two dogs around and taking out the trash so pretty much itll be a toy lol. Manual transmission as always.
Old 02-17-2014, 11:58 AM   #26
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
if u get Taco...stick is great clutch pedal little odd placement ( push in up ) i find. As for engine size i love the six lots of power and really only little worse on gas , i find with the four u gone drive it harder cos its under power for the truck basically u will burn more gas with the four ...lol
i love the four door short box 4x4 stick...for V6 set up as for 4 cyl the only way i would get it is reg cab short box 4x4 , little lift ..light on its feet.
Reason i dont drive one....way to much money :(
Old 02-18-2014, 10:36 PM   #27
You'll be sacrificing a lot of power/tq by going with the 4-cylinder. Since it's not your DD, I'd get a V6. You'll have 3,000 lbs more towing capacity (6500 vs 3500). mpg are 18/21 and 16/21 respectively, so it's not like you'll be gaining very much gas savings going with the 4-cylinder. However, I don't think you can get a regular cab with a V6 and stick shift, smallest would be the access cab. Of course, this is for the 2014 Tacoma.
Of course, the V6 will cost more than the 4-cylinder, but it'll also have a higher resell value down the line. That's just my take.
Old 02-26-2014, 02:06 AM   #28
Blue09
Yea from what I can tell they didnt make any reg cab V6 Tacomas at all atleast in recent years. Which sucks cuz the access cab isnt big enuff for my 2 big ass dogs to ride back there and I dont like the look of the double cabs so they were gonna be in the back either way. So a reg cab 4x4 with V6 would be perfect.
Old 02-26-2014, 07:57 PM   #29
How about a Tundra regular cab with a 4.0?
Chevy Cruze ECO earns an astounding 42 MPG EPA Highway rating! Kal-El Off-topic / Other Cars / Everything else Discussions 26 02-05-2011 10:29 AM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
