Old 02-17-2014, 02:06 PM   #26
Originally Posted by rcvmini View Post
Saw some nice metalic red ones but I have to order them Could I use the stock shorter ones in the mean time?
The depth of the wheel's lug nut holes doesn't matter. The key is to look at the shape of the surface that the lug nut touches and make sure that it is the same shape as the lug. So, if it has a taper (and the angle of the tapers match), you would use tapered lugnuts (which is what the OEM ones for the steelies are). Some alloy rims have really tight holes, where you can't fit the stock lugs with a wrench into. In that case you have to use smaller outer dimension lugs.
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 05:55 PM
Sway bar opinions Nelson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 12-10-2008 06:40 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Need Opinions on Package Options bdc87 New YARIS Purchase Forum 8 06-26-2007 01:55 PM
Opinions on '07 Hyundai Accent hatch? Yaris Revenge Off-topic / Other Cars / Everything else Discussions 44 05-07-2007 11:18 PM
