Old 02-18-2014, 06:29 PM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Well the Borla is a straight through glass pack type muffler so the back pressure should be the same on both pipes. I have a feeling i didn't put the connection together tight enough and was causing some vibration through the exhaust causing the knock sensor to pull timing. It was mostly in the lower RPM range.
modify stock axle back muffler what do you think AND189 DIY / Maintenance / Service 15 12-21-2009 07:23 AM
Doug Thorley header + muffler delete curik Performance Modifications 4 11-04-2009 06:48 PM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
Aftermarket muffler. THiS KiDD Performance Modifications 17 11-12-2008 09:00 AM
Rusty Muffler Hangers YAR1S General Yaris / Vitz Discussion 14 10-24-2008 07:22 PM
