#32 |
![]() Drives: 2008 yaris sedan Join Date: Dec 2013
I had a look behind the fuse box non of the connectors were unplugged but there are around 6 connectors behind there and i also popped the dash off and the plugs at the junction box seem to be connected there are many plugs at the junction box i tried looking through all of them but if you know the specific one that would help greatly. Otherwise I will check all of them again.
Do know if there is any thing that could be fried between the wiring from the fuse box to the cluster or do you think its the wires that have broken |
| Tags |
| cluster, door indicator, gear indicator, parking brake warning, tachometer |
| Vitz 2001 1.0 manual rpm | diesel2901 | DIY / Maintenance / Service | 4 | 09-23-2011 12:02 AM |
| yaris and yaris S | Y@R15 | General Yaris / Vitz Discussion | 54 | 09-14-2009 12:40 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
