Old 03-20-2014, 12:02 AM   #16
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I'm pretty sure I didn't need a ring terminal and that the ground wire already had a fork terminal on it. The red ring terminal you see in some of the photos was from the cruise control install I believe.
*** Connecting to the brake was the hardest part! If you have large forearms or hands pay attention to this: Try not connecting any connectors to the module and just taping the connectors to the point where the module will eventually be wire wrapped to, but leave some slack for just in case. Doing this will give you much more room to reach back and make the connections to the brake. You can just pop the connectors into the module last. I would recommend this.***
33.7 mpg in PA
bad is offline   Reply With Quote
crimestopper, diy, remote entry, remote lock, remote start
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
remote start tool&parts list? bad DIY / Maintenance / Service 2 12-18-2014 12:22 PM
DIY: Debadge/Black out Emblems TinyGiant DIY / Maintenance / Service 113 08-02-2014 02:44 PM
Remote start and gas mileage? Palmer812 In Car Entertainment + Electronics (audio / video / alarm) 16 03-04-2010 07:23 PM
