![]() Drives: 2007 yaris Join Date: Mar 2014
STUCK IN PARK
chang thee 10 gauge #7 on my cover no luck
OK. The next step up from that fuse is the 120A fusible link on the positive battery terminal. If you remove the red cover you will see the two fuses built into the black plastic chunk.
Did it suddenly stop working or did it start after you did some work on the car?
#4 | |
Dealer or junkyard is likely the only place you will find it.
ACC fuse in the under-dash panel and DOME in the under-hood panel.
| Will not shift into park | AlaskaYaris | DIY / Maintenance / Service | 7 | 02-19-2013 12:37 AM |
| Car got stuck in gear? | mr_miles | DIY / Maintenance / Service | 1 | 03-24-2012 11:25 AM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 06:37 PM |
| "click" when shifting into park | The little red pill | General Yaris / Vitz Discussion | 2 | 05-25-2009 12:43 AM |
| September 22-23rd Colt State Park, Bristol, RI Meet!!, come one come all!!! | dexter_5000 | New England | 17 | 09-24-2007 01:43 PM |
