Does it fit without those big washers?
Sent from my iPod Touch |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
Yea it would I guess. But it needs the washers as gas as I know.
Klick |
Does the offset bushing fit in opening tight or loose without the washers?
Loose very loose. The Whiteline bushing with the washers are the same size as oem 62mm. I measured it before removing d OEM bushings.
Klick |
Btw thanks for assisting.
Klick |
I guess if it doesn't fit without modifying the car to fit it can't be the right kit.
But it looks like the smaller round part of the washers should fit inside the space Sent from my iPod Touch |
Whiteline Bushing Install Questions
Remember it should be a very tight fit. So if it doesn't slide in you might just need to give it a little motivation.
Yea the smaller round part fits inside the spaces but then they are not in a line thus the bolt doesn't fit thru them. Also the hole for the top washer doesn't line up with the top bolt hole too.
Klick |
So if you just put all the metal parts together and put it in place you can't get the bolt through?
No I cannot get the bolt through.
Klick |
Can you post a photo
ok tomorrow I will try n take a photo showing it. I am thinking if I widen the holes and cut off the low tab it should fit up fine.
Finally got them installed I had to widen the holes on the washers and they were a very difficult fit still. Thanks everyone who was assisting.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
Did you put them in the right direction?
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#15 |
Really hope I did...fingers crossed. Will know when I go for an alignment tomorrow.
Klick |
#16 |
Cool, well at least there in there.
Funny I'm installing my lowering springs again and my upper bearing on the drivers side strut is shot.... again. Oh well the replacement is way better than OE from Canadian tire. Uses a sealed bearing on the lower part compared to the OE being open with a stupid foam gasket. Sent from my iPod Touch |
#17 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
They are tight (for a reason) but no modifications are necessary to put the spacers in.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#18 |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
Update to this? Everything was installed correctly and no issues with the caster and did it increase?
| FS NorCal: Yaris/Prius C Partout: KW V3 / Whiteline / Greddy Ti-C / Etc | B2FiNiTY | Items for Sale by private party | 25 | 04-25-2014 01:47 AM |
| Whiteline Polyurethane Bushing Review | Monstro | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-15-2013 11:24 AM |
| alternator bushing JAMMED ! | Siffleu | DIY / Maintenance / Service | 12 | 10-22-2010 10:12 AM |
| Gauging Interest: Whiteline Front/Back Adjustable Sway Bars | RaptorRacing | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 12-15-2009 04:23 AM |
| NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
