toyota
does 3m tape work for side skirt
anyone tried 3m tape for side skirt would it hold? ,, broke a couple of pins which toyota dont have available for sale.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
Yes 5yrs and still holding no pins just a thin strip of 3m tape down the length of the side skirt. I just added one extra screw underneath the rear, there was a factory screw hole there for something else.
toyota
good to know..thanks... so tape on the side and screw/bolt on each end..right?
It did not work for me. especially if you take out the fender liner. The front tires will kick rocks past the fender and in the door jams between the top of the side skirt that lays on the rocker panel and the bottom of the door. small rocks would get between the side skirts and rocker panel where the tape was and over time would come loose. I ended up just drilling holes and using some flat screws to hold the side skirt firmly to rocker panel.
toyota
Even when the skirt is screwed on both end.?
3M should be okay. Sounds like you will be able to use tape in conjunction with the remaining pins you do have.
no, Just tape. I should have screwed it in first. After I screwed it in, it looked more flush and I didn't have any more issues. I do autocross alot and I have made some contact with a few cones in the past 2 years. If you have fiberglass skirts, be aware that rocks will eventually chip away the paint on them. I recommend using some form of clear vynl wrap on them to peek the paint together. Another thing I wish I did. My body kit is trash now..
^ 2007 RS, he has factory RS skirts.
well screw you guys and your OEM side skirts...
toyota
ill work with 3m this weekend we shall see...
My original style RS spoiler has been held on with nothing but 3M for 6yrs. Rock solid.
There should be no issue with a skirt (along with pins). Just make sure you heat the surfaces where the tape is to be applied with a hair dryer. You want it warm.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I zip tied mine on the ends and have the 3m tape down the length of the rocker panel, but it's only been a few months and its already starting to come loose. I'm using an aftermarket skirt.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
toyota
Ok I got the clip was the wrong part # but I still thank weeyari for the help but here's the right part # for this clip atleast Canadian and they are $1 each clips.
#15 | |
. Good price, I had been given $4 each.
| OEM Side Skirt Fitment HB/Sedan | eablola69 | Cosmetic Modifications (Exterior/Interior) | 6 | 03-18-2014 01:00 PM |
| Side skirt molding | ilikerice | Cosmetic Modifications (Exterior/Interior) | 4 | 08-09-2011 04:48 AM |
| Strange tape where the spare tyre is kept | mikastefh | General Yaris / Vitz Discussion | 8 | 06-15-2010 07:48 AM |
| Double side tape from visors | DandiDani | General Yaris / Vitz Discussion | 12 | 10-15-2009 07:49 PM |
| Rear skirt needed | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 6 | 01-09-2009 04:54 PM |
