Old 05-02-2014, 11:49 AM   #4
Originally Posted by Normex View Post
Thank you for your timely response. I bought the 07 slightly used and I presume the power lock were factory. The button is situated between the two
front seat. And yes if the doors are locked we can open the car with the door latch. Do you have an idea also for the rear hatch door non locking issue?
Many thanks
Norm
Do you only have the lock/unlock switch between the two seats (and not on the arm rests)? If so, I still think it may be aftermarket. If you want to PM me your VIN I can tell you for sure how it was built from the factory.
For the hatch you will need to remove the plastic hatch trim piece to see what is going on there. The trim piece is only mounted with panel clips, so just get your fingers under the bottom edge and pull outwards to release them.
