Old 05-10-2014, 10:37 AM   #28
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
I don't believe so on either.
Cutting and re-welding would actually be a reasonable approach, although the simpler solution is to use hub spacers. Using a mismatched set of one 10 mm and one 13 mm Penguin Garage spacer brings them almost perfectly equal. To make them dead on you could purchase a set of 10's or 13's and grind one down to where both sides are identical.
Yea we have considered spacers. But we are looking to maybe bring the wheels in more than just even them out. They already poke out some on each side and hoping to look for options to bring them in rather than just crazy camber..
sasquatch is offline   Reply With Quote
Yaris Sport 2009 wheels question andr3w Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2013 07:28 PM
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
