#19 |
What does Toyota recommend in your country? I keep reading people using 10W30 in very hot countries.. but you might also want to change oil more frequently, ie at 3k miles instead of 5k miles.
what kind of filters are available in your country? If you can get toyota filters, just go with that. |
#20 |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
1) engine flush is not good, it flushes even the oil films on the pistons/rings.
2) use a multigrade multipurpose oil (for diesel and gas engines), then use it for 1000km (~600 mi) then drain it and use a good oil like mobil 1. 3) never use lower than xxW-40 oil, since your country is a bit warm/hot, oil will thin out a lot if its like xxW-30 or lower (don't worry about the xx since that is cold weather rating). if your oil thins out a lot, oil degredation will likely happen more/faster. 4) toyota nz and zz engines were/are rumored to be prone to sludging, don't use conventional oils for more than 5000km (~3000mi) and FULLY synthetics for more than 10k km (~6000mi). i would assume this is mostly city driving and since sludging is partly caused by pollution as well as long oil change intervals. if it is dusty where you drive most of the time, be sure to change the air filter every 4th oil change. HTH :) Last edited by jcboy; 05-14-2014 at 11:23 AM. Reason: oil filter --> air filter :) |
#21 | |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
If engine is badly sludged, pan has to be dropped to inspect oil pickup screen to prevent oil starving. So yes, one needs to know what one is doing of course. |
#22 |
4 years of P90X!
I use the Fram Extra Guard # PH4967
#23 |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Give http://www.auto-rx.com/ a try...
#24 |
My dog used to drink out of the toilet after flushing it its probably OK...
#25 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
#26 |
#27 | ||
if that's how it's done, (10% at a time), then it should be good. )Quote:
that's correct, oil filters every oil change. air filter is what i meant.
#28 |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
better filters
I think there are better filters out there. I heard the fram has cardboard end caps.
Also, I only change oil every 10k miles with synthetic and it seems OK, but there is a lot of freeway mixed in with the driving. Also Mobil 1 has a extended version with a 15k service standard. regards to all, Alan |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
