Old 05-15-2014, 11:34 AM   #22
mpcv2000
mpcv2000's Avatar
Drives: 2004 Echo HB Hatchback 2 Door
Originally Posted by Ryze268 View Post
In the .pdf it says the tach signal comes from the Black wire on the C13 connector, is this true?
I'll answer that if you don't mind.
C13 ( Black ) is the tach signal and to get my 05 Tach to work in my 04 I took the signal on the OBDII port that is also the black wire and hooked it up to the Black wire on the C13 connector.
This is a very easy swap if you take your time.
mpcv2000 is offline   Reply With Quote
Yaris Liftback cluster w/tach for SALE!! jose3sgte Items for Sale by private party 5 11-13-2013 10:35 AM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
2007 Yaris Sedan cluster, with Tachometer. (Won't fit Liftback) H3LlIoN Items for Sale by private party 3 09-18-2011 03:55 AM
