#217 |
yeah i got Stance coil springs to replace the 4k/4k from my cusco setup. about 50-60shipped per pair on ebay.
How much preload are you running on the front and back? you can lower the back to an extent with the strut height, but keep in mind every time the back wheels are off the ground, the spring will be pulling the strut apart, also you reduce the strut shaft travel length.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 05-20-2014 at 02:06 AM. |
#218 | |
![]() ![]() ![]() ![]() Drives: 2011 Toyota Yaris Join Date: Feb 2013
#219 |
9K/9k Stance 6in springs.
yeah keep preload to a bare minimum, least for the front. The rears, actually you cant preload it, because moving the strut body just moves amount of shaft travel. But still you can bust a strut . You cant get any more lower/higher than what the springs/ spring perch / lock rings give you or lack there of. So trying to thread that rear strut lower, wont give you more low. The front yeah, the shock body adjusting will control the car height, and not the spring lock ring.
#220 |
Form>Function
@terrence I cannot tell the difference lol. Also do not shorten your shock much more. All of us with Megans who went too short with out shock length wound up blowing the shock.
#221 | |
Ahh gotcha. Guess I gotta leave it alone for now until I get those springs. They're shorter right? That way I can add the locks/perches and still go as low? Really?? Haha damn I hella see it. Definitely man I won't be touching them. I'll have to deal with it until I get shorter springs. So I'll be okay if I leave it where it is? |
#222 |
Yeah, measure your springs should be 7in. I have 6in stiffer springs. Basically measure how much your rear springs compress compared to its free length. You can calculate how much drop any spring will give with stated spring rates.
Course you could go with same spring rate but shorter springs.
#223 | |
#224 |
Yeah, seeing they are sold in pairs you can test to see how much drop front and back you can get. I do recall I only decided to buying the 9k 150mm once i saw they had it (gotta keep checking or maybe just ask them), i bought a pair of 8k 175mm (7") to test.
I only went with the 9k, because i calculated it would allow me to lower a bit more (i forgot the number) and still be at the same height compared to 4k when fully loaded with passengers. Be warned that 9k, is pretty stiff.
#225 |
Form>Function
@ezhacker1 regarding your post about shortening rear shocks for preload/length. If you have the shock too long and once lowered at ride height the inner valve pushes down pretty far towards the bottom of the inner tube, wouldnt you call that preload too?
Also if the shock is set so long that once the car is lowered to its static height if the valve is resting agains the inside of the bottom of the tube, wouldnt that hold the car up anyways? in that case, shortening the shock would allow the valve to move back up the inner tube at static height and then that would allow the car to settle down more. just like discussing these things with other suspension experts lol |
#226 |
Tested the cars ABS today. Yup, as of right now no ABS.. Lol. I gotta figure out what happened to that and the Vehicle Stability Control already. Those lights on the dash are not fun to look at. A friend of mine told me that if we did stretch the wires out on accident it will be costly to replace.. *sigh*
#227 | |
#228 | |
This is just my understanding of how suspension works. The front shocks have preload abililty which is just pre compressing the spring even before the car is on the ground, but that spring will push against the shock hat, tugging on the shaft ![]() The rear struts need to be set up in such a way at static load with wheels on ground that the shaft has enough travel both up and down without bottoming out. I measured static shaft length, compared that to how much shaft is left with car on ground, and calculate at max load how much more the shaft will travel. Then i adjust the strut height accordingly, making sure that with wheels off ground the spring and perches don't fall out.
#229 |
Form>Function
right, so in the rear you have some preload to keep the spring taught even with wheels in the air, mine i have way longer. I have never bottomed mine out, when they were short I topped them out all the time.
I was considering shortening the shock to see if it was holding me up at all, but with my recent mods my fitment is perfect so idc now haha |
#230 |
#231 | ||
#232 |
Well to a certain extent the strut height should keep the spring assembly from falling out, but if you take out perches rings, or swap to shorter spring length then depends.
Ill look at your car at the coming up meet.
#233 |
Sounds good man. Thank you. You have an 09+ Yaris right? So you have ABS and VSC?
#234 |
ABS yes, VSC no.
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 12:25 PM |
| 2012 Vitz from the 2011 Tokyo Auto Salon | CTScott | Third Gen Yaris General Discussion | 14 | 02-10-2011 08:06 AM |
| Is UA-NCP13 1.5L Manual Trans a Vitz RS? | WesSunday | General Yaris / Vitz Discussion | 1 | 11-28-2010 10:47 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| A German Yaris/Vitz/Echo ;) | we-to-11 | Photo-Video-Media Gallery | 5 | 06-27-2007 08:26 PM |
