Old 06-17-2014, 06:24 PM   #1
dthomas5768
Drives: 2006 Toyota Yaris
Smile
Hello im new at this forum. I recently purchased an 2006 Yaris and the speedometer is gone out of wack. Basically not showing the correct speed.
Can you help with the repair or can you recommend someone.
Thanks,
dthomas5768
dthomas5768 is offline   Reply With Quote
Old 06-17-2014, 09:42 PM   #2
Thanks,
dthomas5768
Typically that would be caused by the speed sensor on the transmission being broken. You can verify that by using an OBDII device and see if the incorrect speed is also shown on there.
Tags
change, cluster led, color, speedometer, tach
WTD: ECM, Instrument Cluster, Headrests, Quarter window chrisjaldin Willing to Buy by private party 8 09-03-2011 12:12 AM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 08:03 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 11:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 10:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 11:22 AM
