Old 07-09-2014, 09:21 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Question Advice Installing Shocks/Struts and Lowering Springs
Hello All,
I feel bad for adding to the hundreds of threads regarding lowering springs and shocks/struts, but I do have a minor specific question.
I finally got all of the parts needed which are the Tein S-Tech and the Tokico Blues. I’ve been reading quite a lot of PDFs on how to do lowering spring installations and I’ve found so many examples of removing the springs, but I have yet to find a good pointer on how to actually replace the rear shock absorbers. I’m pretty sure it has to be fairly easy for the hatchbacks, but I can’t figure out what panels I’ll have to remove for the shock absorbers. I was reading the official Toyota repair manual and it only specifies the removal process for the Sedan.
I also wanted to confirm the following tools are what I need, disregarding the wheel removal process…
1) Hacksaw to cut bump stops
2) 9/16 sockets,
3) 9/16 box wrench
4) 19mm socket
5) 17mm box wrench
6) 6mm allen key
I’ve heard about using an offset wrench to avoid the cowl wiper removal process. Apparently a 17mm offset box wrench? I have an allen key but it has no 90 degree bend, seeing the “Tanabe DF210 Spring Install” thread it seems I will need one specifically with some kind of bend, am I correct?
Thanks a lot for the help!
vaironl is offline   Reply With Quote
AG Lowering Springs + XA Raceland Rear Springs! So-Cal!! braytonia Items for Sale by private party 6 09-21-2014 10:30 AM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Which lowering springs with stock shocks/struts Palmer812 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-08-2010 11:00 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
