Old 07-24-2014, 09:05 PM   #4
Your picture of the error light doesn't display, but you can read the error code(s) of the VSC using a jumper between two pins on the OBDII connector.
Jump the two pins with the ignition off.
Switch the ignition to ON and watch the ABS and SLIP lights.
If there are no stored codes the lights with flash in a constant .25 sec on/off pattern. If there are stored codes they will be shown as a group of long flashed follows by a 1.5 second pause followed by a second group of long flashes. After all codes are shown there will be a 4 second pause and then they will repeat.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Do you love your car? CanIHazYarisHatch? Third Gen Yaris General Discussion 49 03-04-2013 12:28 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
